theDrew Samba Member
Posted: Wed Jun 08, 2016 10:20 am Post subject: Fan whine |
Guys,
I'm trying to track down why my fan whines so much --
Nothing stuck in the fan or the doghouse that I can find.
Its a 36hp Scat shroud, full thermostat flaps and I have a venturi ring.
Thoughts?!
_________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Wed Jun 08, 2016 10:38 am Post subject: Re: Fan whine |
Are you sure it's the fan or the tension bearing? _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Jun 08, 2016 10:40 am Post subject: Re: Fan whine |
Glenn wrote: |
Are you sure it's the fan or the tension bearing? |
good idea -- I didn't look at that _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
Posted: Wed Jun 08, 2016 4:06 pm Post subject: Re: Fan whine |
well I took the idler off, the bearing seems good. No noise or play. I don't think thats it. _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
drumbum68 Samba Member
Posted: Wed Jun 08, 2016 4:30 pm Post subject: Re: Fan whine |
Bearings in the alternator? Fan not rubbing I assume. Bet it's the alternator.
Speaking of bearings...those are some nice looking adapters on your linkage!
Why do you have your center arm on the same plane as the carb arms?
Are you sure the noise isn't internal?
T Hollis Samba Member
Posted: Wed Jun 08, 2016 4:35 pm Post subject: Re: Fan whine |
I'd go with a bearing on its way out.
Take a very long screw driver and touch the working end to several places all around the alternator (engine running of course), the other end to your ear and I'll bet you find the source.
One other thing, if the bearings start to go out the alternator pulley will begin to walk and eat into you aluminum case, which is not good. |
Posted: Wed Jun 08, 2016 5:17 pm Post subject: Re: Fan whine |
Not internal
Not rubbing.
Those bearings on the carb arms I picked up from somewheres on the great internet. If I can find the order I'll let you know. _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
Posted: Wed Jun 08, 2016 5:35 pm Post subject: Re: Fan whine |
Yeah, I'm pretty sure I know where they came from. |
j-dub Samba Member
Joined: November 09, 2003 Posts: 865 Location: Phoenix, AZ
Posted: Wed Jun 08, 2016 8:38 pm Post subject: Re: Fan whine |
Has it always wined or has it recently started?
Mine began wining after I installed a welded and balanced fan, it sounds similar buy not as bad as yours. I don't know what brand the fan was, I bought it from the local VW shop. I know it is not rubbing, the sound is different.
I have been thinking about swapping it out however it has not been a priority. _________________ 1957 Oval rag
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on." |
Posted: Wed Jun 08, 2016 8:41 pm Post subject: Re: Fan whine |
j-dub wrote: |
I have been thinking about swapping it out however it has not been a priority. |
Its a welded and balanced fan I got from CIP1 way back when, when I put together my gofast engine. Its always whined, I'm just now trying to figure out if I can make it quieter. _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
vugbug68 Samba Member
Joined: June 25, 2006 Posts: 2696 Location: sacramento
Posted: Wed Jun 08, 2016 9:15 pm Post subject: Re: Fan whine |
Just tell people its supercharged _________________ 71 Super - Backroad Thrasher
66 Corvair - Weekend Cruiser
90 4 Runner - Muddin |
Posted: Wed Jun 08, 2016 9:18 pm Post subject: Re: Fan whine |
vugbug68 wrote: |
Just tell people its supercharged |
for the first two years I thought it was cool, but now i'm getting alittle tired of it. _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
mark tucker Samba Member
Posted: Wed Jun 08, 2016 11:03 pm Post subject: Re: Fan whine |
something contacting the armature? or fan? I had one wine a bit when I got it new. the end cap screws were not tight and the armature was lightly tuching somethen probably the plastic/cardboard/ fenalic insulators on the stayture. I recentered the end cap and tightened the screws. |
Pizza Eater Samba Member
Joined: October 10, 2013 Posts: 81 Location: Chico, CA
Posted: Thu Jun 09, 2016 10:55 pm Post subject: Re: Fan whine |
drumbum68 wrote: |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Fri Jun 10, 2016 9:57 am Post subject: Re: Fan whine |
My welded fan makes a strange sound as well. Between a whine and something caught in bicycle spokes noise. I've had the fan in and out several times and I'm still stumped. Fwiw I'm running a traditional belt/ import alternator/ welded fan. My next step will be to set the fan and shroud on an engine on my stand, and spin it with a 110v motor. It'll probably be easier to figure out without all of the engine noise _________________ modok wrote:
Posted: Fri Jun 10, 2016 10:59 am Post subject: Re: Fan whine |
Talking John @ ACN, he says its a fan spacing issue. I'll put it apart tonight and see what it is.
So...what do I shim the fan with? _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
Posted: Fri Jun 10, 2016 12:48 pm Post subject: Re: Fan whine |
fan shims. |
Posted: Fri Jun 10, 2016 12:50 pm Post subject: Re: Fan whine |
Pulley and fan shims. Do you have the backing plate on correctly? |
jason Samba Member
Posted: Fri Jun 10, 2016 1:00 pm Post subject: Re: Fan whine |
In the 80's some of the local guys would drill their shrouds, making that sound. Reminds me of a cazoo. |
