first five off road modifications I should do?
Metal Twister
Metal Twister is offline
PostPosted: Sun Jun 05, 2016 10:18 am    Post subject: first five off road modifications I should do? Reply with quote
Have a Thing that I need to get more off road worthy. What would be the first five modifications I should do to make it noticeably more off road friendly? Keeping in mind I want to keep it street legal as well. Thoughts or direction?
Change is Opportunity!
Instagram=metaltwister
Aerindel
Aerindel is offline
PostPosted: Sun Jun 05, 2016 1:30 pm    Post subject: Re: first five off road modifications I should do? Reply with quote
1: re-enforced front shock towers.
2: boxed trailing arms (if you have IRS)
3: Skid plate.
4: Roll cage
5: 5-6 point harness.
Homemade woods/street, bug out rail. IRS, Balljoint front end. 1967 1600cc DP, Weber 32/36 progressive, tri-mil quiet pack. Rear only cutting brakes.
http://www.thesamba.com/vw/forum/viewtopic.php?t=630046
Metal Twister
PostPosted: Sun Jun 05, 2016 2:08 pm    Post subject: Re: first five off road modifications I should do? Reply with quote
Interesting... do the shock towers tend to fold over? Break off? It doesn't seem that there would be that much pressure on them unless you went with coil overs on the front?
Thanks for the reply by the way. I will be building a cage for it and already have the 5 point harness's. Yep a skid plate is a must as well... Hum, better get busy!
Dale M.
Dale M. is offline
PostPosted: Sun Jun 05, 2016 6:52 pm    Post subject: Re: first five off road modifications I should do? Reply with quote
Only one..Sell thing to me....
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Aerindel
Aerindel is offline
PostPosted: Sun Jun 05, 2016 9:42 pm    Post subject: Re: first five off road modifications I should do? Reply with quote
I haven't heard of them outright folding over but they get bent and crack eventually. They take a ton of force when you slam over bumps. You can just weld a gusset on the inboard side. Not a hard fix and reenforces a vulnerable spot, also when you do your roll cage tie it into your rear shock mounts to strengthen them too.
Something else, everyplace where there are two parts spot welded together along a seem run a continuos weld on the seam. Shock towers, trailing arms, etc. Easiest way to strength everything.
Also, upgrade your over travel stops, they get a lot of use when your running off road. The stock snubbers in the front get bent upwards and the rear ones tend to pop off...at least mine where, lost four of them before I changed to a bolt on buffer and mounted it to the top instead of the trailing arm to get it up out of the way. I use a hook and rod travel limit system in the front.
3gengines
3gengines is offline
PostPosted: Mon Jun 06, 2016 3:52 am    Post subject: Re: first five off road modifications I should do? Reply with quote
Dale
http://www.thesamba.com/vw/classifieds/detail.php?id=1926789
Here is a really nice one in need of a new home. It was loved by a good friend of mine that has passed.
dirtkeeper
dirtkeeper is offline
PostPosted: Mon Jun 06, 2016 6:43 am    Post subject: Re: first five off road modifications I should do? Reply with quote
The thing front beams already have reinforced shock towers.
Here's a few
New quality shocks
Studs For the wheels , makes putting those big wheels and tires on so much easier
Quality aftremarket or from other car seats. This along with good shocks can improve the ride a lot
Transmission straps
Good carburator filter
Metal Twister
PostPosted: Mon Jun 06, 2016 9:54 am    Post subject: Re: first five off road modifications I should do? Reply with quote
Ok so I guess most of this stuff has already been done by the PO?
The wheels have studs, after market trailing arms of some type, Good looking long Bilstein shocks on the back and new Gas-A-Just shocks up front, body lifted, and after market high fenders. The front end is cut and turned and the tranny is strapped in. The engine im told is a 1776 with a pointless distributor along with a Weber Carb with a good air cleaner attached. It is also sporting a nice aluminized exhaust. Not sure if it is the hot set up for off road though, seems to be close to the ground? He threw in a second transaxle that he said was a close ratio 3rd and 4th if that sounds right? and a set of paddles for the sand. I don't think any of this stuff has ever been used, if so very little.
Based on your posts here it looks like a cage, a skid plate, and mount the seats along with the 5 pt harness that are from something else should get me going. Very Happy
It sure looks like crap so some type of paint will be in order in the near future as well. Kinda thinking camouflage might be easy and fun at the same time? Pros cons?
And thanks for the reply's, its a great help! Ive had it in the barn for a year now and think its time to make it street-able once again. Last time it was on the street was 2010.
Aerindel
Aerindel is offline
PostPosted: Mon Jun 06, 2016 1:03 pm    Post subject: Re: first five off road modifications I should do? Reply with quote
What carb is that?
Metal Twister
PostPosted: Mon Jun 06, 2016 2:15 pm    Post subject: Re: first five off road modifications I should do? Reply with quote
That is a Weber 32 36 DFEV Anyway that is what is stamped in the back of it?
Good or bad? I know the guy who built the engine here in San Diego. He runs an import shop and he tells me he fiddled with the carb for a good part of a day when he set it up. His customer drove it home and started stripping it down for paint... it ever went back on the road. I get it though I have a few of those projects that seem to always take the back seat to something more important.
Aerindel
Aerindel is offline
PostPosted: Tue Jun 07, 2016 3:45 am    Post subject: Re: first five off road modifications I should do? Reply with quote
Thats what it looked like but I wasn't totally sure from the picture.
As for good or bad...well I'm biased because its what I have and I put a bit of effort into getting mine to work well.
Some people totally hate them and will tell you to throw it away. Personally,I just think that they are misunderstood and it seems none of them come to people set up properly.
Trying to figure out how to get mine happy is what brought me to the forum in the first place, it was the one thing that had me totally stumped on my own.
I found this thread immensely useful. I'm still running the wrong distributor for it but I did re-jet and fabricate a warm air intake for it and noticed huge improvement.
http://www.thesamba.com/vw/forum/viewtopic.php?t=386388
Knowing what carb that is and seeing those pictures my new top 5 mods are
1 Heated manifold.
2 warm air intake system (you can replace your exhaust at the same time with something that fits up higher and out of the way.
3 check and re-jet the carb if needed
4 Replace lower engine cooling tin (you need that)
5 Relocate your fuel filter outside of the engine compartment.
Metal Twister
PostPosted: Tue Jun 07, 2016 10:55 am    Post subject: Re: first five off road modifications I should do? Reply with quote
Thanks again...
So why a heated manifold? I'm in San Diego at sea level and Ive never had an issue with things getting cold?
Warm air intake? Heater Boxes? Things have gas operated heaters.
Its been professionally re-jetted but I might want to tinker a bit with that.
I ran the lifted bug on my avatar for 8 years with out tin and it worked just fine. Im not so sure it is as critical as everyone says? Ive had several rails and never ran any type of tin... Just saying?
Fuel filter out side of the engine compartment is a must! I have a couple of the glass ones that I would feel much better running than the plastic disposable models.
And thanks for the link... I will dig into that this evening. Thanks again it is truly appreciated!
dustymojave
dustymojave is offline
PostPosted: Fri Jun 10, 2016 9:03 pm    Post subject: Re: first five off road modifications I should do? Reply with quote
I put my glass fuel filters in a piece of clear tygon tubing with zi[ ties to protect it.
Lower tins are not needed, especially without the heater boxes.
I don't think your Thing is sitting low. What are you basing that on? Looking at images of Class 5-Open Bajas with 6x7 arms on the back and +4 arms with lift spindles in the front? Look at this Crumco race Baja with all of that listed above. See if yours sits so low in comparison to it.
Or did you just mean the exhaust? If you want it better, it would have to be custom made.
The carb will work. As Aerindel said, some think you should just throw them away. Some think they're the best. Try it before you decide whether you should get rid of it.
Umm...6-point belts are for lay-down seating like a formula car. You know...F1, Indy, etc. 5-Point is what is needed in a Thing. If a cop gives you troubles over it...They think you have to have a 3-point belt and race belts are not tested for DOT approval...you MAY have to put in and use stock-type 3 points when driving on the street. Even if they're not as safe. Cops almost NEVER care about what is better...just what is legally approved. Often they don't know that either. You can have both in the car.
Richard
SoCalBajas Member
Metal Twister
PostPosted: Fri Jun 10, 2016 9:35 pm    Post subject: Re: first five off road modifications I should do? Reply with quote
First off thanks for the well thought out reply. It is appreciated!
The car sits plenty high, I was concerned about the exhaust which looks low since the body lift was added. I will try to modify it my self before running out and purchasing something else.
Same with the carb. Since posting this up I've talked to the guy who built the engine. He says he spent a good part of a day dialing in that carb and insists its a good one.
A lap belt is all that is required in Ca. For that year. And to be honest I will most likely use the 4 point since the crotch strap is a major PITA!
And finally the glass in the Tygon tube is a great idea. Will do.
Thanks again and I will check out Crumco's link.
dustymojave
PostPosted: Fri Jun 10, 2016 10:51 pm    Post subject: Re: first five off road modifications I should do? Reply with quote
3-point belts were required in all cars by California in 1968. Things were sold in the US in 1973 and 1974. So an officer COULD require 3-point belt use for your car.
The purpose of the crotch strap is to keep the lap belt down on your hips. Shoulder belts pull the lap belt up as they are snugged. The crotch belt resists that. Lap belt riding up into the belly is what killed NASCAR great Fireball Roberts. His death was what caused NASCAR to require 5-point competition belts in 1965. The lap belt MUST BE SNUGGED 1ST. In many years of checking racers as they approach the start of races, I've many times found race car occupants with the shoulder to crotch very tight and in a straight line from crotch to shoulder, with the lap belt raised up to the shoulder/crotch belts. The belts would have injured or killed people belted like that in a serious crash.
With 5-point belts:
- Lap belt holds you in the seat.
- Shoulder belts hold you back so you don't hit the dash or steering wheel or break your back as you bend forward.
- Crotch belt keeps the shoulder belts from pulling the lap belts up.
I have 5-point belts in my Baja Bug. Yup. They're a PITA. But then, so is death.
My Baja is a 58. No factory belts. No bosses in the B-Pillars to mount 3-point belts Bosses COULD be welded in. In California, I'm not required to wear seat belts in that Bug. But it's had belts since before my dad bought it in 1963 from his friend who he had installed lap belts for.
Didn't mean to turn this into a personal rant for seat belts. But I'm not turning it around now.
Richard
SoCalBajas Member
Metal Twister
PostPosted: Sat Jun 11, 2016 10:35 am    Post subject: Re: first five off road modifications I should do? Reply with quote
No problem at all. I think the Thing was categorized as a utility vehicle until 1974. As a utility vehicle there were a few safety standards that did not apply to utility vehicles. Front safety glass and three point harnesses come to mind. Lap belts are all that are required by law in the 73 to 74 181 Things. In 75 they were re categorized to a passenger vehicle and VW decided it wasn't worth it to bring them to us safety standards for import to the USA. They pulled the plug and hence we have 2 years of Things to choose from.
I have no intention of racing or anything close to racing with the Thing. I'm more interested in slowing down a couple clicks and enjoying the desert that I hauled arss over for years on the bike racing district 38. Just turned sixty and gave up the KTM Lc4 for four wheels. I'm just trying to think ahead and make it on / off-road worthy the first go around.
Thanks again!
Vanapplebomb
Vanapplebomb is offline
PostPosted: Sun Jun 19, 2016 7:55 pm    Post subject: Re: first five off road modifications I should do? Reply with quote
You have a Thing, the shock towers would already be gussetted from the factory...no need to gusset what you got unless someone dropped a bug beam into it somewhere along the line. Wink
1800 Type 4 Berrien 295
tripicana
tripicana is offline
PostPosted: Mon Jun 20, 2016 11:10 am    Post subject: Re: first five off road modifications I should do? Reply with quote
It would still be a good idea to weld the seams of the towers
foam cowboy hats aren't good helmets.
Metal Twister
PostPosted: Sat Jun 25, 2016 11:54 am    Post subject: Re: first five off road modifications I should do? Reply with quote
I know it is a stock beam with the adjusters installed.
The shock towers are skip welded vertically on the seam of the shock towers. Were they originally just spot welded or were the seams welded as well? Im guessing someone has already gotten to the seams and welded them? Here is a pic of the beam and you can see a gusset of some type in the upper right corner. So is this a stock beam that has had the adjuster installed.
dustymojave
PostPosted: Thu Jun 30, 2016 2:51 pm    Post subject: Re: first five off road modifications I should do? Reply with quote
Yes. It's a stock Thing beam with the factory shock tower gussets. If the pinch seams have arc weld along the edge, it has been welded by someone other than the factory. The shock towers only got spot welds at the factory. The gussets got arc welds, IIRC. The adjusters have been added. That should make a nice beam and work well. You can upgrade. Whether that's really necessary depends on how radical you intend to use it. Bumper to bumper cage structure including support for the beam would be needed long before an upgrade to the beam. Then you need to upgrade, spindles, arms, shocks, steering, etc. to go with the beam.
Richard
SoCalBajas Member
