Speedometer conversion Subaru VSS to VW MK2 mechanical cluster
Forum Index -> Water-cooled VW Share: Facebook Twitter
scirocco29!
scirocco29! is offline
PostPosted: Mon May 30, 2016 7:24 pm    Post subject: Speedometer conversion Subaru VSS to VW MK2 mechanical cluster Reply with quote
Hi, new guy here. Sorry if this post isn't in the right section.
Anybody here know what I would need to take the VSS signal from a Subaru 6-speed transmission and convert it to a MK2 mechanical cluster (from a 1988 VW Scirocco 16v)? Both are originally in KPH if it can help. From my own research, I could only find the Dakota Digital ECD-100 unit. Anyone know if the "Ford clip-on" they mention is similar to VW's MK2 cluster attachment? Even if it does, I think that the pulses per revolution need to match as well?
I'm not interested in the "why" and "it's stupid" type of comments. I'm posting this on this forum since I know that many Samba owners swap in Subaru stuff into their bus.
Any other solutions available out there?
Thanks in advance!
crsmp5
crsmp5 is offline
PostPosted: Tue Jul 12, 2016 8:41 am    Post subject: Re: Speedometer conversion Subaru VSS to VW MK2 mechanical cluster Reply with quote
bus speedo cable to wheel... so no real application like you thought...
in europe they had a digitfz dash.. it would be vss
what you need is a reverse electric motor to spin the speedo head that the vss controls the rpm of... i see no reason one annot be made... but i cannot say i can think of any real reason on a vw application.. i guess if a guy was putting a 06 or newer driveline in a 93 to 74 wc vw this would be needed.. as they use the abs as the speed sensor.. but i think gm/ford applications would be much more common for the retro rod cult using new drivelines with classic interiors/cars
[url=http://cdn2.driiive.com/7037.jpg]Click to view image[/url]
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
