vintage fiberglass Samba Member
Joined: January 23, 2006 Posts: 485 Location: Reading, Pa
Posted: Mon May 30, 2016 5:32 pm Post subject: Crash box trans went from when to when? |
Can anyone tell me the year they changed from the non sycro crash box like in 1950 to the partially synchronized trans? 1952 zwitter maybe? Tim |
Robert Chambers Samba Member
Posted: Mon May 30, 2016 5:37 pm Post subject: Re: crash box trans went from when to when? |
I had a 1952 Standard Split with a non syncro crash box. At the same time (1978) my daily driver was a 1953 Deluxe Oval with syncro 2,3 and 4 gears. Both cars were completely original. Hope that helps? _________________ '63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117 |
usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Mon May 30, 2016 10:01 pm Post subject: Re: crash box trans went from when to when? |
vintage fiberglass wrote: |
Yes, it came with the Zwitter in october 1952.
But only in the deluxe models. The Standards kept the non syncro for many years more. _________________ Master of my domain! |
Posted: Tue May 31, 2016 4:31 am Post subject: Re: Crash box trans went from when to when? |
Thank you so much for the info. Is thee any way to tell from the outside of the trans if it is a non sycro crash box or a synchronized one? Like by a number? or you have to pen it up? |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Tue May 31, 2016 12:03 pm Post subject: Re: Crash box trans went from when to when? |
Yes, I think Ev is right about the oil fill plug location. _________________ John Henry
'57 Deluxe
'56 Single Cab |
splitjunkie Samba Member
Posted: Tue May 31, 2016 4:40 pm Post subject: Re: Crash box trans went from when to when? |
EverettB wrote: |
I could be wrong but I think you can look for the existence of the side filler that is accessible from the top.
This is a feature of only crashbox transmissions.
1947 example:
I believe the later standard crashbox cases were ribbed just like the synchro transmissions so they didn't have the side filler. _________________ Chris
Posted: Tue May 31, 2016 10:04 pm Post subject: Re: Crash box trans went from when to when? |
If it has this sort of side filler it is a split box and generally not synchronized at all.
The next generation up from october 1952 came in standard models as a non synchronized "crash box" and in deluxe or export models as a semi synchronized box. Those two kinds look the same from the outside I think.
You can see a difference when you take off the nosecone.
There is a bearing peaking out a few millimeters more at the synchronized ones.
If it is post 1954 and has a parts number on it a standard part should start with 111 ... and a deluxe part starts with 113 ...
Or if it still has the original brake backing plates on the axles you can separate them by cable versus hydraulic brakes because the standards where produced on with cables for a long time while the exports had hydraulics. _________________ Master of my domain! |
sunroof Samba Member
Joined: October 06, 2006 Posts: 1774 Location: Winnipeg
Posted: Wed Jun 01, 2016 8:43 am Post subject: Re: Crash box trans went from when to when? |
Don't forget about Canadian custom. They never came with crash boxes.
Don _________________ Better and better mistakes! |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Fri Jun 24, 2016 11:46 am Post subject: Re: Crash box trans went from when to when? |
splitjunkie wrote: |
EverettB wrote: |
1947 example:
I believe the later standard crashbox cases were ribbed just like the synchro transmissions so they didn't have the side filler. |
this trans filler ended with the access panel in the luggage area behind the rear seat in 9/52 or with the intro of the zwitter... _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Fri Jun 24, 2016 1:07 pm Post subject: Re: Crash box trans went from when to when? |
Access over the trans ended earlier than 9/52, my 6/52 doesn't have it...but a 5/52 does have it _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1462 Location: Finland
Posted: Mon Jun 27, 2016 6:02 am Post subject: Re: Crash box trans went from when to when? |
I purchased a box full of crash box gears, spacers, lock rings??
They box was in a rusted out VW bus for over 20 to 30 years. They all have surface rust on them but some still have the NOS paper part numbers tags.
Does surface rust hurt the function of a gear in a trans? I know the bearing areas have to be smooth, but what about the teeth on the gears? Tim |
Posted: Mon Jun 27, 2016 7:13 am Post subject: Re: Crash box trans went from when to when? |
Canīt you clean up the surface by a brass brush or by blasting with a not too aggressive media? _________________ Master of my domain! |
Posted: Tue Jun 28, 2016 2:43 pm Post subject: Re: Crash box trans went from when to when? |
I soaked them in de-greaser first and got the grease off. I then poured some penetrating oil into a can and now some of them are soaking in that. I will take a few pics then of individual gears. I still can't believe someone let a box full of NOS crash box gears sit in a box unprotected for 20 to 30 years and let them get like this. But then again, when the newer trans were out these parts were probably worthless. |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed Jun 29, 2016 4:18 pm Post subject: Re: Crash box trans went from when to when? |
Any chance there was cosmoline on them? I have a few NOS gears in VW boxes and the gear is wrapped in a wax paper like material and covered in cosmoline. The gears look used or greasy, but a soak in lacquer thinner melts the cosmoline off and the gears are shiny steel.
I'd think a light glass bead blast and polish the surfaces where bearings/bushings/seals ride and you may be able to use them. I guess it really depends on the pitting if any. |
Posted: Wed Jun 29, 2016 6:12 pm Post subject: Re: Crash box trans went from when to when? |
Nancy,
Yes you were right on a few. Some of them had such hardened cosmoline on them I thought they were shot and they did cleaned up. A big thank you! Some have surface rust and some is coming of in penetrating oil. I think the gears will work, the bearing are going to get tossed. Thanks for the help.
Appreciated! |
Posted: Wed Jun 29, 2016 7:28 pm Post subject: Re: Crash box trans went from when to when? |
Good to hear!
Good luck with the tranny work. |
koolerkrotch Samba Member
Joined: August 25, 2015 Posts: 54 Location: CT and FL
Posted: Mon Jul 11, 2016 4:25 am Post subject: Re: Crash box trans went from when to when? |
Tim wash off all the penetrating oil with laquer thinner and soak the parts in Wd-40 brand "rust remover soak" about 25$ for a gallon but in 3 days you'll have like new metal. It's so clean it'll start rusting again within a half hour so have something to spray preserve them. I'd even try the bearings you'll be able to see if the balls are pitted.. You might end up saving one or two. |
Posted: Fri Jul 15, 2016 8:53 am Post subject: Re: Crash box trans went from when to when? |
I just was in Lowes and saw that product for the first time in a gallon can and wondered how it works. A big thank you! I will try it and see. I would rather clean the gears this way them have to media blast them somehow.
I will let the trans rebuilder look at all the parts and decide what is good and what is bad. They know from experience. |
