koolerkrotch Samba Member
Joined: August 25, 2015 Posts: 54 Location: CT and FL
Posted: Mon May 30, 2016 9:34 am Post subject: Correct routing of brake line around/past pedal assembly? |
Anyone have a picture of this? ..seen a number of various routes/ curves/ and bends (all hack jobs) between where the brake pipe emerges through the Napoleon hat, then ends up going rearward along the left side of the tunnel. What's the proper route/look? thanks everyone. |
splitjunkie Samba Member
Posted: Mon May 30, 2016 10:14 am Post subject: Re: Correct routing of brake line around/past pedal assembly? |
Sorry for all the crud but this is a '51 split that was driven for 11 years then parked so this should be factory.
_________________ Chris
Posted: Mon May 30, 2016 11:47 am Post subject: Re: Correct routing of brake line around/past pedal assembly? |
Great pic, thank you. That's some beautiful crud that same camera angle in my car was nothing but pavement. |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Fri Jun 10, 2016 1:15 am Post subject: Re: Correct routing of brake line around/past pedal assembly? |
koolerkrotch wrote: |
So then you would not need brake lines any more, considering that you already have the upgraded Flintstones brake kit _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
