joshuabiles Samba Member
Joined: November 23, 2007 Posts: 81 Location: Turner Oregon
Posted: Sun May 29, 2016 2:11 pm Post subject: 1600sp exhaust questions |
I have a 1600sp motor that had the factory muffler on it but I installed the headers low clearing style with a stinger. Do I just start it up and drive or do I need to do the timing or anything after installing the muffler system? Thanks |
Miklo ¡Chale!
Joined: August 27, 2008 Posts: 2058 Location: Antelope Valley, Ca
Posted: Sun May 29, 2016 2:21 pm Post subject: Re: 1600sp exhaust questions |
I too a 1600sp.
I just did the opposite. Went from a stinger to an original exhaust/peasooters.
It ran a little too rich for me once I put the stocker back on. A quick adjustment and I was good to go. I should also mention... the recent weather change I also adjusted the choke as well.
I didnt touch the timing. _________________ ✠Miklo✠
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote: |
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche... |
Posted: Sun May 29, 2016 2:32 pm Post subject: Re: 1600sp exhaust questions |
Awesome Glad to hear some insight on the subject. |
vamram Samba Member
Posted: Sun May 29, 2016 3:17 pm Post subject: Re: 1600sp exhaust questions |
No need to touch the timing but you're likely to have icing problems at some point if you're using a center mount carb. This is because the headers aren't designed to properly flow exhaust gasses thru the heat risers. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Old n' slow Samba Member
Joined: October 29, 2012 Posts: 619 Location: Western Maryland
Posted: Sun May 29, 2016 4:45 pm Post subject: Re: 1600sp exhaust questions |
VeeDubDoug wrote: |
I too a 1600sp.
I didnt touch the timing. |
Not trying to be a b-- buster, but I'm really curious.......by a quick adjustment do you mean change the main power jet or just actually "adjust" an external screw (as in idle adjustment)? _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
All my daily drivers gone but not forgotten;
1964(sunroof)1967 & (2)1968 Beetles , 1968 Squareback , 1963 (23 window )Deluxe Sunroof Bus , 1969 Westphalia camper, 1974 Dasher , 1985 Vanagon , (2) 1981 Rabbit Diesels & a 1991 Jetta Diesel . |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Miklo ¡Chale!
Posted: Sun May 29, 2016 6:35 pm Post subject: Re: 1600sp exhaust questions |
[quote="Old n' slow"]
Quote: |
Not trying to be a b-- buster, but I'm really curious.......by a quick adjustment do you mean change the main power jet or just actually "adjust" an external screw (as in idle adjustment)? |
A good question, I did not specify. I did NOT change jets... Only fiddled the mixture and idle screws.
I knew someone would poopoo the ol' stinger too...
Lean is bad, yes... but you can run lean with any exhaust.
NOT ONCE have I ever had a valve problem from a stinger. Used them EXCLUSIVLY for over 20 years! On street cars, used daily.
Cheap header problems and low flanges sure... Im sure the icing may also be true with some of these cheapo headers... but I'm lucky, or unlucky enough to live in southern California.
... I understand the theory of the problem... However, I go by experience. _________________ ✠Miklo✠
'55 Type1 "Ozma"
