concepts12 Samba Member
Posted: Sun May 29, 2016 8:42 am Post subject: 6v generator cooling fan set up? |
I got this great generator off of eBay.
http://www.ebay.com/itm/VW-Generator-12Volts-GR11X...PhgTiJj-3w
It's 12v but its the size of an earlier VW 6v. Really a great find
Im having trouble figuring out the orientation of all the parts. I've got this nice diagram but it don't show all the 6v parts
It's missing this part
Where dos it go? |
Mr. Mike Samba Member
Joined: January 30, 2015 Posts: 513 Location: Shoreline, WA
Posted: Sun May 29, 2016 8:46 am Post subject: Re: 6v generator cooling fan set up? |
That piece secures the fan shield to the generator.
Mike _________________ 1964 Sedan 6 volt |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Sun May 29, 2016 8:50 am Post subject: Re: 6v generator cooling fan set up? |
_________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Sun May 29, 2016 1:27 pm Post subject: Re: 6v generator cooling fan set up? |
Hey thanks guy |
glutamodo The Android
Joined: July 13, 2004 Posts: 26310 Location: Douglas, WY
Posted: Sun May 29, 2016 2:17 pm Post subject: Re: 6v generator cooling fan set up? |
So do you have a fan with the extra holes for the generator cooling?
_________________ Andy T.
Posted: Fri Jun 17, 2016 12:32 pm Post subject: Re: 6v generator cooling fan set up? |
I do
thanks glutamodo |
Posted: Fri Jun 17, 2016 12:49 pm Post subject: Re: 6v generator cooling fan set up? |
Also shown in the diagram above is a dust cover. Do you know, off hand, where I can pick one up? The engine I have will be driving a Dunebuggy. It would be nice to keep the generator clean on the inside. Would this cover effect the cooling of the generator? |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Sat Jun 18, 2016 5:50 am Post subject: Re: 6v generator cooling fan set up? |
I bought a new generator for my bus and it came with those dust covers , but I thought it was just a shipping item and thru one away. duh ?... anyway wolfburg west has them listed.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113903531 |
Posted: Sat Jun 18, 2016 5:53 am Post subject: Re: 6v generator cooling fan set up? |
That dust cover won't work... it's for a 105mm diameter generator and he's got a 90mm diameter unit.
edit: I've seen them before, but I suspect they were aftermarket? I just thought I'd look and see if there was a VW part number for a brush cover and I'm not seeing one for 90mm units. Not in the diagram or the parts list.
The Fall 1971 parts book mentions one for 105mm generators under a type 181 part number ("Cover Band - Generator" 181903197)
Porsche used a cover band on 90mm generators on 356 models - but those are expensive. probably wouldn't be too hard to make one out of sheet metal anyway.
