62ItalianRagtop Samba Member
Posted: Sun May 29, 2016 7:41 am Post subject: 62 VW emblem fitting |
Hi, I have some problem fitting properly the VW emblem on my 62.
I used wolfsburgwest clips but It does not join properly to the hood
Any advice ?
I fitted three clips to the emblem before installing it to the _________________ LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/ |
glutamodo The Android
Joined: July 13, 2004 Posts: 26297 Location: Douglas, WY
Posted: Sun May 29, 2016 9:29 am Post subject: Re: 62 VW emblem fitting |
Wait, what kind of clips? If you mean the plastic thimbles, those go on first. If you mean the metal speed nut clips, those go on AFTER you put on the emblem, from below the hood. _________________ Andy T.
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Sun May 29, 2016 9:31 am Post subject: Re: 62 VW emblem fitting |
I cut the ends off of my plastic clips/retainers so that I could fit the emblem more tightly.
It does bother me that it didn't fit well initially. If you come up with a more elegant fix, please share. I think I am going to just press some dum-dum putty over mine. I just hadn't thought about doing that yet. _________________ Plate of shrimp |
Posted: Sun May 29, 2016 11:10 pm Post subject: Re: 62 VW emblem fitting |
glutamodo wrote: |
Wait, what kind of clips? If you mean the plastic thimbles, those go on first. |
Are you sure ? _________________ LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11053 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Mon May 30, 2016 8:51 am Post subject: Re: 62 VW emblem fitting |
The inserts are placed in the HOOD holes..
The emblem is then pressed into the inserts.
If the holes have excess paint thickness it can squeeze the inserts too tight not allowing the emblem to seat.
You would need to gently remove some paint from the hood holes..
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Mon May 30, 2016 10:08 am Post subject: Re: 62 VW emblem fitting |
I removed paint before installing the emblem.
It was quite difficult insert plastic clips into emblem pins.
I had to use some wd40 and a rubber hummer so I think that should be impossible for me to place the clips on the hood and then the emblem. _________________ LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
Posted: Mon May 30, 2016 10:12 am Post subject: Re: 62 VW emblem fitting |
VOLKSWAGNUT wrote: |
Well... that explains my problem. Now I feel _________________ Plate of shrimp |
wcfvw69 Samba Purist
Posted: Mon May 30, 2016 10:20 am Post subject: Re: 62 VW emblem fitting |
Bingo!
After a paint job, the holes are quite a bit smaller from the primer and paint. I bought a cone shaped sanding disc for my Dremel to gently remove all the excess paint from all the molding holes on the body. In a few places, I went to metal but I simply used a small paint brush and hand painted those spots with the car paint, let it dry and then slipped in the clips and or rubber holders. _________________ Contact me at [email protected]
The Samba member since 2004.
UPDATE : I just tried with wolkswagenut advice and now emblem fits better.
Not perfect , perhaps for the damaged pin, but I'm quite satisfied
Thank you _________________ LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
