Bob Brugge Samba Member
Joined: April 09, 2015 Posts: 721 Location: Missoula, MT
Posted: Sat May 28, 2016 6:10 pm Post subject: What to do next |
Hi Guys!
I have been working on my engine for a while now. Now I am down to the expensive parts like the $600.00 IDF’s. Instead of frustrating myself over it, I thought I would bide my time and start on other things.
Here is a partial list of things, just wondering if there are things an owner ought to check and replace as necessary that I haven’t thought of yet.
Things that are done on this 70 STD Beetle include:
1641 sp motor
New hoses between brake reservoir and master cylinder
New MC
Things I am thinking about:
Engine tin seals like maybe on my next days off
Bonnet seal
Window scrapers and channel felt
Headlight beauty rings
NOS chrome door mirrors, pretty sure I haveta have those
Visors
Maybe do something about the strong gas smell
Car starts, stops, and runs fine. Basically I am just looking for some ideas on what to monkey with next while I lament the lack of cash for the more expensive parts. Need to replace wiper switch as soon as I can figure out how to get the old one out _________________ Keep on Dubbin'! |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sat May 28, 2016 6:29 pm Post subject: Re: What to do next |
It sounds like you have a good list of things to do.
In the meantime, maybe hanging a pair of fuzzy dice from the mirror would make you happy. |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2408 Location: Gladstone, Ore
Posted: Sat May 28, 2016 6:34 pm Post subject: Re: What to do next |
Strong gas smell, replace all hoses under the front lid. All of them.
NOS mirrors good luck, Hecho en Mexico are good ones.
Scrapers and felt is good, rebuild your doors, grease the crap out of the the window winder mechanism too.
Special tool is needed to remove switches, MidAmerica sells them as do many other vendors, escutcheon wrench? or something like that.
Speaking of midamerica, i dont get the catalog anymore, I'll have to buy some valve cover gaskets or something, get back on the mailing list... _________________ 1972 1302
HPMX 40's & 019 |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Danwvw Samba Member
Posted: Sun May 29, 2016 10:17 am Post subject: Re: What to do next |
IDF's? are Dual Port Carbs! Just get the Weber-ICT-34's Used for a couple of hundred dollars or new with everything for just over $400 dollars.
These are set-up for a single port.
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Sun May 29, 2016 1:33 pm Post subject: Re: What to do next |
I would adjust your brakes, just to be sure. It's amazing the freeplay/dead travel you can get rid of just by turning out your star adjusters a tad. might as well check the clutch pedal freeplay while you're at it.
Gas filler and vent hoses replaced if needed, it sucks smelling gas the whole ride to work.
Front bonnet/hood seal. if your channel is muffed, get the mexican style that slips over the lip of the hood itself.
Breather line from oil filler to air cleaner, and lower road draft tube seal. assuming you are running a decent aircleaner (and the best ones for a stock carb are the OEM oilbath or paper element style) there will be proper provisions to hook up the line. you would be surprised at how this keeps your engine drip free over time, and you wont see anymore oily mist coating anything either.
Also, if running the proper aircleaner, you should also hook up the warm-air intake to the carb, it connects to a "stove pipe" coming up through the tin. this and properly functioning manifold heat are crucial to getting the most performance and MPG out of a centermount carb.
Distributor- set up a decent SVDA (if running a 34-3 carb) and time it properly, but with a single port you most likely have an older 30 series or h30/31, then you want to get yourself a vacuum advance only dizzy. I like the 205k. 009 will work, but not my preference for a stock carb.
Visors are a pretty big deal for me personally, way better when you actually have them and they stay put when you fold them out.
Engine tin seals are a pain, but can be replaced with the engine in if you dont mind the finagling required. these can make a huge difference in oil and head temps if missing. while you are at make sure all your tin fits well, and fix any gaps that you find. _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
Posted: Mon May 30, 2016 2:41 pm Post subject: Re: What to do next |
Danwvw wrote: |
Yeah, I should have mentioned the IDF's are going on a 1849cc dp engine that I have been building. I have a set of Weber ICT's but was warned against using them due to their age and an unknown amount of crapus in the teeny tiny passages.
[/quote] I would adjust your brakes, just to be sure. It's amazing the freeplay/dead travel you can get rid of just by turning out your star adjusters a tad. might as well check the clutch pedal freeplay while you're at it. [/quote]
The brakes seem to be just fine, properly adjusted, etc. _________________ Keep on Dubbin'! |
andrewvwclassic Samba Member
Joined: January 25, 2012 Posts: 920 Location: los angeles
Posted: Mon May 30, 2016 3:14 pm Post subject: Re: What to do next |
Don't over carb the engine unless you are planning on getting a set of P&C's soon. dont forget all the extra plumbing as well. you can break the needle and seat if the pressure goes too high. |
vamram Samba Member
Posted: Mon May 30, 2016 3:43 pm Post subject: Re: What to do next |
Lingwendil wrote: |
Engine tin seals are a pain, but can be replaced with the engine in if you dont mind the finagling required. these can make a huge difference in oil and head temps if missing. while you are at make sure all your tin fits well, and fix any gaps that you find. |
Everything ling said, and I would add replace ALL soft fuel lines - including the one by the tyranny!! _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
mark tucker Samba Member
Posted: Mon May 30, 2016 4:36 pm Post subject: Re: What to do next |
put some good duel ports on it and use the idf's. |
Posted: Mon May 30, 2016 5:48 pm Post subject: Re: What to do next |
What type of heads, cam and exhaust are you going to use? Those are probably the three most important factors when determining carb choice. As far as ICTs, they are good little carbs, and I ran them on a mild Type 4 engine for quite awhile. If you are going to error on carb size, it is better to be a little too small, then too big. The main thing that you have to look out for on the ICTs, is shaft wear. If the shafts are tight and you can not feel them wiggle, then you are good to go. If the shafts wiggle, then the engine will run fine while your driving, but you will have an inconsistent idle. As far as tiny passages, they are no worse then other carbs, and a soak in Beeryman's, and compressed air will get you going. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
