gerg a.k.a. 6volt65
Joined: April 25, 2003 Posts: 5454 Location: Monroe, LA
Posted: Sat May 28, 2016 4:14 pm Post subject: Reinstalling my felt seal for the sunroof . . . Which way? |
So I am finally refurbishing my sunroof on my '65. I pulled the old felt seals off from 2011 and now I am not certain I had it in right. Does the bead 'overhang' along the top of the seal go towards the body, or aim inwards towards the sunroof panel? In other words, the completely flat side of the felt seal glues towards the body, or away? May be obvious to some.
I had the bead towards the body and TOO low (flat side away from body) . . . want to get it right now. If I blow up the wolfsburgwest image, they show the bead towards the sunroof panel (very generic drawing though). If that is correct then I had it wrong all this time.
I presume the rear felt has the bead aim upwards . . . but now not sure either.
Also, how high above the body should it stick up?
Many thanks for replies - really need to button this up. New everything, should be nice _________________ Gerg
. . . I got 99 problems and my bus ain't one . . .
'65 Sunroof Beetle
'65 Vert
'60 Singlecab |
grandpa pete Samba Member
j.goodspeed Samba Member
gerg a.k.a. 6volt65
Posted: Sat May 28, 2016 4:34 pm Post subject: Re: Reinstalling my felt seal for the sunroof . . . Which way? |
Thanks for the reply! I JUST found a pic showing that. I had it backwards all this time!
What about the rear portion? Looks like in pics the bead goes UP - that is how I had it installed before.
THANKS!!!!!! _________________ Gerg
'65 Sunroof Beetle
'65 Vert
'60 Singlecab |
Posted: Sat May 28, 2016 4:35 pm Post subject: Re: Reinstalling my felt seal for the sunroof . . . Which way? |
Yes the rear portion does go up and as it wraps around you'll see that it will set the height for the front portion which will again be just slightly above the roofline itself. _________________ Jeremy Goodspeed
www.goodspeedmotoring.com
www.goodspeedmotoring.net |
