Meco Samba Member
Joined: January 09, 2009 Posts: 148 Location: Chula Vista, CA
Posted: Sat May 28, 2016 3:23 pm Post subject: Steering Box/Pitman Arm Shaft |
What's up everyone.
While I was under the car today working on the front end alignment, I noticed that the steering box shaft, at the point that the pitman arm connects to, moves up and down when you move the steering wheel side to side. I can hear a clunking noise when I move the steering wheel sharply to the left.
The steering Box is a new TRW unit with about 500 miles.
Is this movement normal? I'm not sure if it was always this way.
I looked through all of the steering box threads and don't think you can adjust this out.
My steering wheel play isn't excessive - about 1".
Please let me know if you think that the box has a problem! Thanks. |
Meco Samba Member
Posted: Tue May 31, 2016 3:06 pm Post subject: Re: Steering Box/Pitman Arm Shaft |
Bumping this, hoping to get a reply. Can anyone offer any insight? |
cbeck Samba Member
Posted: Tue May 31, 2016 3:17 pm Post subject: Re: Steering Box/Pitman Arm Shaft |
Mine didn't move like that. |
Meco Samba Member
Posted: Wed Jun 01, 2016 9:33 am Post subject: Re: Steering Box/Pitman Arm Shaft |
Thanks for the reply, check. I kind of figured that! |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Wed Jun 01, 2016 12:38 pm Post subject: Re: Steering Box/Pitman Arm Shaft |
There was a recent thread about such movement. I can't remember if it was in the Bug or Type 3 forum, though. Search for it... it was alleged to not be a problem, if I remember right. |
Meco Samba Member
Posted: Wed Jun 01, 2016 5:03 pm Post subject: Re: Steering Box/Pitman Arm Shaft |
Thanks for that. I found it in the T3 forum. And after some more reading, I'm thinking that my pitman arm may have moved down on the shaft even though I have shims between it and the steering box. I did take a hit off-road not long ago..
If the pitman arm didn't move, and there is a gap between the shims an the box, maybe the box was damaged. |
