johnnydollar Samba Member
Joined: May 20, 2016 Posts: 39 Location: Perilously close to the Motor City
Posted: Sat May 28, 2016 3:22 pm Post subject: 1968 Speedometer? |
I understand '68 had a one year only speedometer.
The one on the left is what I think is for a '68, but it does not match the one in the '68 I'm working on. Of course, the installed speedo in the pic could've been changed at some point as someone has done some modifications to the dash.
Which one is correct for '68?
[/b] |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2408 Location: Gladstone, Ore
Posted: Sat May 28, 2016 3:36 pm Post subject: Re: 1968 Speedometer? |
The left one is 68. pretty face with fuel gauge. Installed one is 70 or later, I say that only because my old 69 had a chrome center ring where that one is white painted, and 69 didn't have 10th's of miles either. One other thing! oil light in the 68 is green!!
Another thing, the "R" in the 68 fuel gauge would have been a white arrow looking mark, not the red as in the 70's speedo pictured. _________________ 1972 1302
HPMX 40's & 019 |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Sat May 28, 2016 4:13 pm Post subject: Re: 1968 Speedometer? |
Here's my factory-installed date-stamped '68 Beetle speedometer that has never been removed from the dash:
_________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Zundfolge1432 Samba Member
Posted: Sat May 28, 2016 6:18 pm Post subject: Re: 1968 Speedometer? |
Marked 5-68
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Sat May 28, 2016 6:25 pm Post subject: Re: 1968 Speedometer? |
1969 did have a tenths dial, after chassis number 119474781 (Jan 1st 1969) _________________ Andy T.
Posted: Sat May 28, 2016 6:55 pm Post subject: Re: 1968 Speedometer? |
glutamodo wrote: |
1969 did have a tenths dial, after chassis number 119474781 (Jan 1st 1969) |
Interesting, and thanks for the information, see pic of my 69 speedo face. i wonder if the chrome ring went away at the same time as 10th's showed up? It is actually 3 pieces sandwiched, the center smaller ring acting as sort of a rivet holding them together. This is from my first bug, aquired in the 80's, speedo went into at least 2 other cars since, it died before I knew any better to rebuild but I did save the face as a wall ornament!!
HPMX 40's & 019 |
Posted: Sat May 28, 2016 7:57 pm Post subject: Re: 1968 Speedometer? |
I'm sure you're right that it changed along with the 10ths digit. I have a 3/69 speedo head here with the white line. _________________ Andy T.
nbuscemi Samba Member
Joined: May 30, 2009 Posts: 733 Location: Fort Worth, Texas
Posted: Sun May 29, 2016 6:10 am Post subject: Re: 1968 Speedometer? |
To the OP, my 1968 Bug has the same speedo as the one on the left. Integrated fuel gauge with the lines between the numbers.
-Nick- |
Posted: Sun May 29, 2016 8:54 am Post subject: Re: 1968 Speedometer? |
Thanks guys! Great information here! |
markj60616 Samba Member
Posted: Sun Oct 02, 2022 8:12 am Post subject: Re: 1968 Speedometer? |
glutamodo wrote: |
I'm sure you're right that it changed along with the 10ths digit. I have a 3/69 speedo head here with the white line. |
I have a 1970 Beetle built in January of 1970 that has a speedometer dated 10/69 that has both the chrome trim ring around the fuel gauge and the 10ths digit! _________________ 1970 Type 1
original paint
original interior
original engine
1978 Type 2 Panel Bus
original engine 2.0L FI
2014 Beetle 2.5L |
