mjklaser Samba Member
Joined: April 30, 2010 Posts: 6 Location: Brookline, NH
Posted: Sat May 28, 2016 1:55 pm Post subject: torque spec for man transaxle/trans drain/fill plug '74 S Beetle |
Hello fellow Bug owners... Sorry that I'm not using the search function, but in a hurry... I need to know what is the torque spec for the (17mm hex socket) drain & fill plugs for the manual transaxle/transmission for a '74 Super Beetle 1600cc?
I also need to know what is the torque spec for the Oil Pressure-Relief Spring Plug? These are in the 1600cc dual-port engine...
Thanks kindly, in advance, for your help...
mjklaser |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Sat May 28, 2016 2:27 pm Post subject: Re: torque spec for man transaxle/trans drain/fill plug '74 S Beetle |
The trans fill and drain plugs are tapered fit. Just tighten them till you have good tension on the hex wrench.
The oil pressure relief plug does not have a torque spec in the manual that I have. So again tighten till there is a good resistance and then monitor it for a few miles. If a leak develops tighten just a little more.
Just be careful not to strip the threads.
Welcome to the samba. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Sat May 28, 2016 5:05 pm Post subject: Re: torque spec for man transaxle/trans drain/fill plug '74 S Beetle |
Manuals typically state 14 ft lb for the gearbox filler plug and drain plug.
The relief plug is meant to be simply hand tightened with a large screwdriver until you slightly crush the gasket. _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Bruce Samba Member
Posted: Sat May 28, 2016 5:10 pm Post subject: Re: torque spec for man transaxle/trans drain/fill plug '74 S Beetle |
You need to own the Bentley repair manual. Torque specs are all in there.
Trans fill and drain plugs are 14 ftlbs. _________________
Posted: Sun May 29, 2016 9:35 am Post subject: Re: torque spec for man transaxle/trans drain/fill plug '74 S Beetle |
Thanks for the replies! Yah, found my Bentley manual, 14 lb-ft confirmed. No value given for the oil pressure-relief plug, confirmed. Mine has aluminum-looking washers as the 'gasket' for the plug - where in heavens name do you get those? Does anybody know the part number or a link to a good parts fiche that would show it?
I appreciate your help!
Mark |
Bruce Samba Member
Posted: Sun May 29, 2016 10:41 am Post subject: Re: torque spec for man transaxle/trans drain/fill plug '74 S Beetle |
The aluminum crush washers come in the engine gasket kit. The kits are cheap enough, there's no need to try to hunt down the part number of the individual gasket.
Get a couple of kits. All VW owners should have these kits in stock. _________________
Posted: Tue May 31, 2016 5:17 am Post subject: Re: torque spec for man transaxle/trans drain/fill plug '74 S Beetle |
^^^ Thank you! |
nice-diver Samba Member
Posted: Sun Oct 25, 2020 1:26 pm Post subject: Re: torque spec for man transaxle/trans drain/fill plug '74 S Beetle |
Because the relief valve seals only come as a single per gasket sets designed for single relief cases🙄 _________________ many 68's and 70's bugs...i want a 68-71 bus
People are more violently opposed to fur than leather, because it's easier to harrass rich women than motorcycle gangs! |
