Rmvr53 Samba Member
Posted: Sat May 28, 2016 9:11 am Post subject: wire works instruction sheets on line? |
Installing a wire works harness in my 68 T1. The instructions for the main harness at the dash are cut off at the top and it is not clear where the long red wire goes. I can't tell if its fuse box, ignition or possibly headlight switch. Anyone know where it goes and/or a clean set of instructions on line or here in Samba that will tell me?
thanks
Bill |
boater Samba Member
Joined: November 03, 2013 Posts: 98 Location: North Carolina
Posted: Sat May 28, 2016 9:51 am Post subject: Re: wire works instruction sheets on line? |
As per wiring works, connect fat red power wire from harness to #30 head Light switch. small red wire goes to #50 ignition switch. |
boater Samba Member
Posted: Sat May 28, 2016 9:54 am Post subject: Re: wire works instruction sheets on line? |
google wiring works 68 vw. complete instructions |
Rmvr53 Samba Member
Posted: Sat May 28, 2016 11:37 am Post subject: Re: wire works instruction sheets on line? |
Thanks. I'll try it out on Google |
Rmvr53 Samba Member
Posted: Sat May 28, 2016 3:52 pm Post subject: Re: wire works instruction sheets on line? |
as an FYI - I googled it, got the wire works website, and the same issue is on the WW site. So they just made a bad copy of their own paperwork and have perpetrated it into everything |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sat May 28, 2016 4:10 pm Post subject: Re: wire works instruction sheets on line? |
Skip the "post new forum thread tab," open the "technical" tab and pull up the "wiring" for a '68 beetle. _________________
EverettB wrote: |
FU#5 |
Rmvr53 Samba Member
Posted: Sat May 28, 2016 11:06 pm Post subject: Re: wire works instruction sheets on line? |
When your options in the Technical Forums are :
Performance - Engines/Transmissions
Vintage Speed
Custom Wheel/Tire
Accessories/Memorabilia/Toys
not to be snarky, but under which of those will you find electrical information pertaining to "wiring for a 68 Beetle"? The headings alone leads one to believe that there is nothing in the General Forums having to do with the electrical systems of any VW. If I'm in the wrong Technical Forums section I apologize but the General section was the only one I found on my initial search.
I do have several wiring diagrams already for the 68. I needed help with the Wire Works specific diagrams of which I found out its a corporate problem and not just my copy. But do appreciate your input Sir
Bill |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Sat May 28, 2016 11:48 pm Post subject: Re: wire works instruction sheets on line? |
hitest mentioned "technical tab", not technical forum. Here is the link to the T1 wiring diagrams:
http://www.thesamba.com/vw/archives/info/wiringt1.php
There are a few diagrams that are for the '68 model year. The primary difference is the E-flasher system. Early '68 used a 7-9prong flasher relay. Later on this was replaced with a 4-prong flasher relay. Select the wiring diagram that has the correct flasher relay.
Also, after '69 the brake MC was changed and any MC replacement after this would have used the later type MC w/ two 3-prong brake switches. So you may need to follow later brake switch wiring diagrams if your MC has been replaced. Speedy Jim has a simplified diagram:
_________________ AshMan40
empi3 Samba Member
Joined: October 03, 2015 Posts: 347 Location: SW Wyoming
Posted: Sun May 29, 2016 6:06 am Post subject: Re: wire works instruction sheets on line? |
Not sure if you found your answer yet. If not maybe this will help.
full page
Close up
Link to full PDF
http://www2.cip1.com/v/pdf/Wiring-68-69.pdf
Steven
PS I prefer Wolfsburg West wiring diagrams ALOT more than Wiring Works hand drawn diagram. The harness quality is about the same though IMO |
Rmvr53 Samba Member
Posted: Sun May 29, 2016 9:52 pm Post subject: Re: wire works instruction sheets on line? |
EMPI3 this is the very page I was in reference to. Notice at the top right the top word (or top left on your closer view) is cut in less than half. This is how my set looks as well and upon referencing the Wire Works web site, the same error is on their own site. I was merely trying to find out what the word was.
Ashman thank you. I missed the "tab" part of the comment. I have been on Speedy Jim's site and am using it to update to the 69/70 flasher as recommended in the Wire Works paperwork.
Apologies hitest. I now see the Technical tab on the top of the page.
Bill |
fla2smoker Samba Member
Joined: December 31, 2011 Posts: 574 Location: Parrish, Florida
