boater Samba Member
Joined: November 03, 2013 Posts: 98 Location: North Carolina
Posted: Sat May 28, 2016 8:27 am Post subject: pop out window latch |
Replacing pop out window laches on my 68 Sedan. I see that I need to remove c-clip from piece that goes thru glass. Is there a special tool needed for this task ? Thanks |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2407 Location: Gladstone, Ore
Posted: Sat May 28, 2016 4:00 pm Post subject: Re: pop out window latch |
No I don't think so. small screwdriver to tap/pry it off is all. Been awhile but I don't remember any issues. _________________ 1972 1302
HPMX 40's & 019 |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sat May 28, 2016 4:07 pm Post subject: Re: pop out window latch |
Cletus, as is typical, is exactly right. _________________
EverettB wrote: |
FU#5 |
Posted: Sat May 28, 2016 4:59 pm Post subject: Re: pop out window latch |
hitest wrote: |
Cletus, as is typical, is exactly right. |
Yeah right, tell that to Mrs_zuber _________________ 1972 1302
HPMX 40's & 019 |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5600 Location: 37.5N 77.1W
Posted: Mon May 30, 2016 6:58 am Post subject: Re: pop out window latch |
cletus_zuber wrote: |
hitest wrote: |
Yeah right, tell that to Mrs_zuber |
My wife told me I was Mr. Right, as in Right all the time. I told her she was Ms Right, as in Right Now! _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
DesertG Samba Member
Posted: Thu Nov 16, 2023 11:14 am Post subject: Replacing While In Car - pop out window latch |
Anyone replace the latch while the glass is installed, attached to the car.
Removing clip easy. Getting it back, hard.
How'd ya do it.
_________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9754 Location: Oregon
Posted: Thu Nov 16, 2023 11:26 am Post subject: Re: pop out window latch |
BTDT!
I used one of those wood working clamps to hold the outer pin in place and compress the rubber seal at the same time. It's a bit fiddly.
Use just enough clamp pressure to get the clip in place.
You don't wanna break the glass.
Make sure that you have a tarp or something like that under the car while you attempt to install the clip.
I dropped the clip and never found it in the gravel that is my driveway. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Thu Nov 16, 2023 1:00 pm Post subject: Re: pop out window latch |
Yes, you have to ease that clip in there vertically without it falling. I was trying to rig up a tool. Did you just lay it in there an push with a little screwdriver? _________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
Posted: Thu Nov 16, 2023 1:21 pm Post subject: Re: pop out window latch |
DesertG wrote: |
Yes, you have to ease that clip in there vertically without it falling. I was trying to rig up a tool. Did you just lay it in there an push with a little screwdriver? |
It's been a few years since I installed the widow latch post.
You can use a small set of needle nose pliars to hold the clip and slide it into place.
Your going to need a little creativity with the installation. .
Once the rubber seal is compressed, you should see the groove on the post, install the clip. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Fri Nov 17, 2023 2:44 pm Post subject: Re: pop out window latch |
67rustavenger wrote: |
BTDT!
I dropped the clip and never found it in the gravel that is my driveway. |
Sir, what clamp did you use. I tried all the clamps I had and nothing would hold the outer pin and the inner latch at the same time, which would free up my hands to hold the window and hold a needle nose pliers. _________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
Posted: Fri Nov 17, 2023 8:45 pm Post subject: Re: pop out window latch |
IIRC, I used a bar clamp similar to this,
https://www.harborfreight.com/4-in-ratcheting-bar-clampspreader-68974.html
Like I said earlier, it's been a while since I installed the popout window latch on my car. _________________ I have learned over the years.
Buy Once, Cry Once!
