diablosandwich Samba Member
Joined: January 15, 2012 Posts: 469 Location: Illinois
Posted: Sat May 28, 2016 8:04 am Post subject: 1300 oil pressure |
I recently rebuilt a 1300. I am ready to start it for the first time. Oil pressure while cranking is around 35 psi. What should it be when it runs? It is the original 6mm oil pump. Thanks, Casey _________________ 1966 Java Greens |
glutamodo The Android
Joined: July 13, 2004 Posts: 26307 Location: Douglas, WY
Posted: Sat May 28, 2016 11:23 am Post subject: Re: 1300 oil pressure |
That's kind of impossible to answer definatively. The hotter it gets the lower the pressure will be. Depends on what thickness of oil you're running as well. Factory specification:
_________________ Andy T.
Posted: Sat May 28, 2016 11:51 am Post subject: Re: 1300 oil pressure |
Thanks Andy. That's what I was looking for. I wanted to know what the minimum was. I am using Castrol 10-30 for the first start-up and will probably switch to 30 weight after it is in the car this summer. Casey _________________ 1966 Java Greens |
Posted: Sun May 29, 2016 7:18 am Post subject: Re: 1300 oil pressure |
FYI... The older 1200 Workshop Manual said this, along with a note that it was with 10W30 oil.
So is this with a new cam and/or lifters? normal Castrol may not be the greatest oil for a fresh build unless you add some ZDDP to it. _________________ Andy T.
Posted: Sun May 29, 2016 8:04 am Post subject: Re: 1300 oil pressure |
Thanks for that. It is a new cam and lifters. I started it up last night. The oil pressure was 10 lbs at idle after the first twenty minutes at 2000 RPM. I probably should have used some additive but did not. Casey _________________ 1966 Java Greens |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Tue May 31, 2016 9:07 am Post subject: Re: 1300 oil pressure |
diablosandwich wrote: |
Thanks for that. It is a new cam and lifters. I started it up last night. The oil pressure was 10 lbs at idle after the first twenty minutes at 2000 RPM. I probably should have used some additive but did not. Casey |
Cam and lifter assembly lube before buttoning up the case. ZZDP used with the break in oil and all oil changes thereafter. |
