Mattaxi Samba Member
Posted: Sat May 28, 2016 4:31 am Post subject: Upper push rod tubes oil leak |
Hi, i have a 1300 engine and it is leaking oil, the problem is coming from the left hand side of the lower engine, the oil is dripping from on top of the push rod tubes, what do you think could be the problem?
1958 Beetle |
glutamodo The Android
Joined: July 13, 2004 Posts: 26307 Location: Douglas, WY
Posted: Sat May 28, 2016 5:41 am Post subject: Re: Upper push rod tubes oil leak |
Left hand side... probably oil cooler leaks, or cylinder base gaskets depending on exactly where on the tubes it's showing up. (If it's on the head-end of the tubes, could be rocker studs, but those kind of leaks are not very common on 1300/newer square-boss heads, and when you do see them, they are usually slow long-term seepage kind of leaks) _________________ Andy T.
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Sat May 28, 2016 11:18 am Post subject: Re: Upper push rod tubes oil leak |
Other then what has been said.....a minute hair line crack under the oil cooler rabbit ears (seen that many times in past years working on engines) |
Posted: Sat May 28, 2016 12:33 pm Post subject: Re: Upper push rod tubes oil leak |
That's a good point, I've seen that before as well. _________________ Andy T.
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1668 Location: Niagara Region, CANADA
Posted: Sat May 28, 2016 3:48 pm Post subject: Re: Upper push rod tubes oil leak |
Split or rotted out pushrod tube? |
