eliacona Samba Member
Joined: January 04, 2014 Posts: 46 Location: Palm Beach County
Posted: Fri May 27, 2016 12:30 pm Post subject: solex 28 pci carb seepage |
I have a 36 h.p. motor with the stock Solex PIC carbm with a new gasket fom Wolfsburg West, and it has a little gas seeping from the top gasket, just enough to make it annoying etc.
I understand there may be soetypical factors as to why it does this, one being the two surfaces are not flush because of age, and warping etc.
Unfortunately the gasket that comes form W. West, is very Thin!!! I wonder what remedies could be done to solve this,less having it machined down surfaces.
I would think a thicker gasket couild do the trick. I am reluctant to use Permantex or "Loctite",as I read comments about the possible truouble you can have with so called gasket/sealer makers breaking off and getting into the carb.
When I called the aprent co. "Henkel" the tech guy, said not to use Loctite 515,but some other product hi tack , which I can't seem to get from the "distributors".
Anyway, naturally Wolfsburg doesn't sell the top gasket alone anyway!.
Anyone have some remedies?
Thanks
Paul
56 Oval |
Bug-nut Samba Member
Joined: December 20, 2015 Posts: 488 Location: Knoxville, TN
Posted: Sat May 28, 2016 2:34 pm Post subject: Re: solex 28 pci carb seepage |
my 28pci had the same seepage issue so I finally took it off the car and all apart and used a flat sharpening stone (about 2"x7") to grind and true up the mating surfaces. It took awhile to do properly but it was worth it _________________ 1959 Fjord Blue Volkswagen Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1962 Austin-Healey Sprite
Snort wrote: |
A 59 Beetle is just an Oval-Window car with aspirations of modernity. |
Mr. Mike Samba Member
Joined: January 30, 2015 Posts: 513 Location: Shoreline, WA
Posted: Sun May 29, 2016 8:42 am Post subject: Re: solex 28 pci carb seepage |
The WW carburetor to manifold gasket is thin, aircooled sells one that is 1.5mm thick. Part #N137761 or N137991. As Bug-nut stated, flattening the matting surfaces may also be necessary. _________________ 1964 Sedan 6 volt |
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 879 Location: Lanark County, Ontario, Canada
Posted: Sun May 29, 2016 3:13 pm Post subject: Re: solex 28 pci carb seepage |
A machine shop belt sander, fine grit, will make short work of this problem once the carb is apart. Some carbs are so bad (over-tightening of screws?) that you will see lots of light passing between the two halves held together by hand. I've found carbs with doubled gaskets, but really, anything short of truing up the halves will be a half-measure. _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
Posted: Mon May 30, 2016 5:26 pm Post subject: Re: solex 28 pci carb seepage |
Yes, it makes sense to true up / flatten the two carb mating surfaces, I I assume you used a honing stone? and the belt sander is another method, I have an old Craftsman belt sander, but you suggest a machine shop/
Thanks
for your help.
Paul |
alanhall Samba Member
Joined: February 18, 2006 Posts: 115 Location: Northern California
Posted: Tue May 31, 2016 1:17 pm Post subject: Re: solex 28 pci carb seepage |
Sandpaper (150 grit or so) on a piece of plate glass can be used to true up these surfaces. Done by hand...much more control versus a belt sander. I don't recall if you have to remove the emulsion tube holder or any jets that are above the surface of the carb body. |
Posted: Wed Jun 01, 2016 7:53 pm Post subject: Re: solex 28 pci carb seepage |
If I remember right all I had to remove was the venturi (yes it was a pain but lots of PB blaster and gentle application of heat got it out) _________________ 1959 Fjord Blue Volkswagen Beetle
Snort wrote: |
