nbuscemi Samba Member
Joined: May 30, 2009 Posts: 733 Location: Fort Worth, Texas
Posted: Fri May 27, 2016 11:30 am Post subject: Speedometer issue, needle doesn't move. |
I removed my noisey speedo from my 1968 Bug. Tore it down, cleaned and greased everything inside (worm gears). I reassembled it ever so lovingly only to have the needle not move. I attached a speedo cable to a drill and spun it... Odometer works just fine, but no movement from the needle. I can rotate the needle by hand and moves freely, no binding. Any ideas? I seems like the rotating magnet isn't close enough to the cup, but I couldn't see any adjustments for it. Please Help!!!
-Nick- |
Posted: Sat May 28, 2016 9:20 am Post subject: Re: Speedometer issue, needle doesn't move. |
I've taken the speedo apart a few more times trying to figure out what i did wrong. After many attempts, still no needle movement. Even after much research into the matter I can't figure out how a magnet is able to move an aluminum cup. Doesn't make an ounce of sense.
-Nick- |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sat May 28, 2016 10:52 am Post subject: Re: Speedometer issue, needle doesn't move. |
I think there should be a magnet on the cup too. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Posted: Sun May 29, 2016 6:13 am Post subject: Re: Speedometer issue, needle doesn't move. |
I figured out my issue.... Some how my need ended up on the wrong side of the needle stop causing the clock spring to be way too tight. After fixing that, everything works as it should.
-Nick- |
rsthj Samba Member
Posted: Mon May 30, 2016 12:00 pm Post subject: Re: Speedometer issue, needle doesn't move. |
nbuscemi wrote: |
-Nick- |
You've already solved the problem but the magnet influences the aluminum cup through eddy currents: https://www.youtube.com/watch?v=5BeFoz3Ypo4&spfreload=10 |
