greggy Samba Member
Posted: Fri May 27, 2016 7:32 am Post subject: Clutch Cable Pulley Thoughts |
On the rail buggy Im building I attempting to use a pulley rather than a Bowden tube to achieve the correct clutch cable angle. Ive got a good idea on how to achieve it. No sweat, but its quite an ugly setup. Would someone please advise me on where to see some cleaner- better executed similar setups?? Maybe a link or two..thanks in advance. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri May 27, 2016 7:40 am Post subject: Re: CLUTCH CABLE PULLEY THOUGHTS |
Not only does bowden tube create correct angle it also reduces clutch chatter when releasing clutch.... Think you will not be happy with pulley and bowden tube will be better concept...
greggy Samba Member
Posted: Fri May 27, 2016 8:44 am Post subject: Re: CLUTCH CABLE PULLEY THOUGHTS |
Ok thanks for the input Dale. With the current cable set up I have Id like to try and use the pulley. Try at least..If it works to get me down the road for a test run thatd be great. If not ill take another route. |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2672 Location: West Coast (Michigan's)
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5412 Location: Holland, MI
Posted: Sun May 29, 2016 11:37 pm Post subject: Re: CLUTCH CABLE PULLEY THOUGHTS |
Dale M. wrote: |
Dale |
I would agree with Dale on using the bowden tube. Clutch chatter can be an issue without the tube. You would probably be ok without the tube if the transmission is solid mounted though. But yeah, for anything not solid mounted, keep the bowden tube. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Mon May 30, 2016 4:53 am Post subject: Re: Clutch Cable Pulley Thoughts |
The Bowden tube is necessary because it provides a flexible "constant" spacer. Without it, any movement or twist of the transmission in the mounts translates into a lengthening or shortening of the cable which will cause a varying friction point. This is what causes the "chattering", as you engage the clutch, the transmission moves ever so slightly (or more in some cases), & engages & releases the clutch multiple times as the transmission bounces while you're trying to engage it. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
greggy Samba Member
Posted: Tue May 31, 2016 12:24 pm Post subject: Re: Clutch Cable Pulley Thoughts |
Read you loud and clear guys. I took a look at how the Bowden tube goes through the body on my beetle...no sheet metal on the rail in that
area to attach it properly. How have you guys conquered this problem? |
Nevada Notch Samba Member
Joined: May 02, 2005 Posts: 540 Location: Carson City Nevada
Posted: Tue May 31, 2016 12:50 pm Post subject: Re: Clutch Cable Pulley Thoughts |
I am running pulley system on my rail for both my clutch and throttle cable and it works just fine with no clutch chatter.
It looks kind of cheezy but hey it works!
Won't be able to get pictures for a couple of days though. _________________ 1966 Euro
1600DP
Dual 34mm ICT's
99% Resto-Custom Daily Driver |
cbeck Samba Member
Posted: Tue May 31, 2016 3:32 pm Post subject: Re: Clutch Cable Pulley Thoughts |
Solid motor/tranny mounts. Everybody I know is using hydraulic clutch. |
greggy Samba Member
Posted: Mon Jun 06, 2016 12:00 pm Post subject: Re: Clutch Cable Pulley Thoughts |
*update*
I installed the Bowden tube and low and behold-it seemed to pretty much do the trick. It doesn't really have the correct angle so ill have to work on that.
Still REALLY doesn't want to go into gear. I spent plenty of time taking apart and adjusting the linkages last night to no avail. An old air cooled nut gave me some suggestions-maybe the bearing behind the gland nut too. Anyway, thanks for all the responses. Back on it this evening. |
