DWP Samba Member
Posted: Thu May 26, 2016 9:47 am Post subject: Making touch up paint? |
I painted my car with some PPG single stage paint. During assembly (of course)
I nick and scratched some areas. An I can guarantee there will be more.
Is there a way I can take the leftover paint and make little jars of touchup?
Is a pain in the A... to try and mix 10ml of this to 1ml of that and .5 of this every time.
DWP |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17963 Location: Eugene, OR
Posted: Thu May 26, 2016 10:43 am Post subject: Re: Making touch up paint???? |
Yes, but be sure to use air tight glass jars/lids or small metal paint cans. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Julio_Arcos123 Samba Member
Joined: August 28, 2011 Posts: 52 Location: Los Angeles, California
Posted: Thu May 26, 2016 10:33 pm Post subject: Re: Making touch up paint???? |
Are you mixing the toners yourself?
Make as much as you want if you are. Does it require an activator?(most likely) Do not mix the activator in until ready to use. If u have any old paint cans clean them out with laquer and pour it in there for storage. _________________ 64 bug (o\ ! /o) |
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Sun May 29, 2016 4:16 am Post subject: Re: Making touch up paint? |
Once you add any hardener or activator to the color it has a limited pot life. You can dab just the color on and it will work. It will just take a really long time to dry. Alternatively you can add some of the color to clear if you happen to have some mixed up at the time of application. Really if your mixing touch up with hardener just guess at the ratios. no need to get out your eye dropper. it will still work if it's a bit off. |
