bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Thu May 26, 2016 9:44 am Post subject: Rod Bolt Stretch Gauge |
I don't really care to make one, so does anyone have a P/N# for a decent rod bolt stretch gauge that I can use for various rod types? Low Bugget has one for $150 that I might buy if one from Summit/Jegs etc. is not compatible. |
jason Samba Member
Posted: Thu May 26, 2016 10:04 am Post subject: Re: Rod Bolt Stretch Gauge |
I have a cheap proform 66788 that I bought for $30 on ebay. I took the tip off on the gauge and use a ball bearing instead. Makes it alot more consistant and repeatable. I'm also pretty sure you have a better gauge you could use.
The jegs one looks better made, robust. |
Posted: Thu May 26, 2016 5:39 pm Post subject: Re: Rod Bolt Stretch Gauge |
Thanks Jason. I'ma check that one out. |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Thu May 26, 2016 6:27 pm Post subject: Re: Rod Bolt Stretch Gauge |
Do you have a micrometer that will read it? My mitutoyo combimik does a good job, even with a 5/16 bolt. The anvil is small enough to just fit the recess in the rod _________________ modok wrote:
Posted: Fri May 27, 2016 4:58 pm Post subject: Re: Rod Bolt Stretch Gauge |
I don't have a pointed or round mics. Only flat mics. That's another good method that I didn't consider. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri May 27, 2016 6:36 pm Post subject: Re: Rod Bolt Stretch Gauge |
Make one for the cost if decent dial indicator or old micrometer...
NO... Not mine....
http://images.lmgtfy.com/?q=rod+bolt+stretch+gauge
Posted: Sat May 28, 2016 2:34 pm Post subject: Re: Rod Bolt Stretch Gauge |
I bought the Jegs one for $80. Thanks all! |
