jason Samba Member
Posted: Wed May 25, 2016 9:56 pm Post subject: Change 009 with 019 |
My brother gave me a VJ4BR8, 019. I currently have an 009. What difference will I see by changing it? I am going to get a Magnaspark when they are in stock, so wondering if I should buy the parts to use it in the meantime.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76897 Location: Sneaking up behind you
Posted: Thu May 26, 2016 2:58 am Post subject: Re: Change 009 with 019 |
The advance on the VJ4BR8(019) comes in sooner so it should feel "peppier" off the line.
You'll need a o-ring, points, cap, rotor and condenser. It looks like there's missing/worn fiber washer and shims which is why there's excessive play on the shaft. _________________ Glenn
Member #1009
#BlueSquare |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13846 Location: White Mountains Arizona
Posted: Thu May 26, 2016 6:58 am Post subject: Re: Change 009 with 019 |
Once installed you will like it. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
jason Samba Member
Posted: Thu May 26, 2016 7:58 pm Post subject: Re: Change 009 with 019 |
I have the cap. I bought a condenser and oring from WW today. It also has the fiber washer. It is a little loose though. Glenn, what kind of end play should it have? |
Glenn Mr. 010
Posted: Fri May 27, 2016 2:17 am Post subject: Re: Change 009 with 019 |
Minimal... if the fiber washer is OK, then it could bve the one under the mainshaft inside. There's too much play for it to just be worn metal shims. _________________ Glenn
Member #1009
#BlueSquare |
