kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1160 Location: Woodstock, NH
Posted: Wed May 25, 2016 6:23 pm Post subject: What is this part? |
Looking thru parts box that came with bus - and I came across this. Not sure what it is...any ideas?
_________________ -Kevin
Lincoln, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper |
khalimadeath Samba Member
Posted: Wed May 25, 2016 6:28 pm Post subject: Re: What is this part? |
Clutch or throttle cable? |
Posted: Wed May 25, 2016 6:32 pm Post subject: Re: What is this part? |
Not the clutch cable for my Westy - I just replaced that.
Here is another part from the same parts box - trying to ID.
Lincoln, MA
'78 Westy
'69 Single Cab
Posted: Wed May 25, 2016 6:35 pm Post subject: Re: What is this part? |
E brake? |
73sports Samba Member
Joined: September 26, 2004 Posts: 2107 Location: Warrington, PA
Posted: Wed May 25, 2016 7:23 pm Post subject: Re: What is this part? |
The cable is a heater control cable, and the rod looks like the link rod that goes between the throttle body and the EGR. _________________ I will never lie, but sometimes the truth changes.
Central Jersey VW Society |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Wed May 25, 2016 8:08 pm Post subject: Re: What is this part? |
73sports wrote: |
and the rod looks like the link rod that goes between the throttle body and the EGR. |
X2 _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
Posted: Thu May 26, 2016 3:33 am Post subject: Re: What is this part? |
Looking at my heater control cable -the ends are a heavy or thicker piece of bent metal. Is this for a different year?
I think this is the heater cable for my bus
http://www.gowesty.com/product-details.php?v=&id=2682
The ends are definitely different. _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Posted: Thu May 26, 2016 9:41 am Post subject: Re: What is this part? |
kguarnotta wrote: |
The ends are definitely different. |
There is a right and a left cable, they have different style ends where they hook up to the lever up front. |
Tcash Samba Member
zoobum Samba Member
Joined: June 09, 2015 Posts: 211 Location: Los Angeles
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2714 Location: Hamble, Hampshire, UK
Posted: Thu May 26, 2016 12:41 pm Post subject: Re: What is this part? |
If it is shorter than the length of the bus by a long way it can be a cable for the hot air diverter valve under the front seats on a bus that was built as a Kombi.
This can be removed in one piece complete with the rubber gaiter, as it does not run in tubes like the long heater cables going to the rear where the gaiter will not fit down the tubes. _________________ Ancient vehicles and vessels
Posted: Fri May 27, 2016 5:11 am Post subject: Re: What is this part? |
I think I got it - after reading your posts, and looking more closely under dash - I see that cable must be the right hand heater cable.
While under the dash - I looked at the short rod connecting the fresh air flap - and it looks like the short part I have.
I need to replace the lever that controls where the heat comes out (ie defrost or footwell. I see BusDepot has something that they say will work with some modification. Anyone done this yet? _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Posted: Fri May 27, 2016 9:17 am Post subject: Re: What is this part? |
kguarnotta wrote: |
I need to replace the lever that controls where the heat comes out (ie defrost or footwell. I see BusDepot has something that they say will work with some modification. Anyone done this yet? |
I just saw where the defroster tree cable was available new again, search for "cable" on the Bus Depot site. |
Posted: Fri May 27, 2016 6:16 pm Post subject: Re: What is this part? |
I've got a '78 Westy, the one I see on the Bus Depot site says it needs some modification to work properly. Has anyone tried this yet? Or is there another part on their site? _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
