Jasonmorris Samba Member
Joined: January 10, 2013 Posts: 41 Location: Knoxville Tn
Posted: Wed May 25, 2016 1:37 pm Post subject: Fram oil filter question |
My 56 has the fram oil filter on the firewall. I had to get new hoses for it. One or my hoses go into the generator stand the other screws in nect to the oil switch. My question is which one goes to the top and which one goes to the bottom on the filter housing. It is a stock 36hp. |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Wed May 25, 2016 4:52 pm Post subject: Re: Fram oil filter question |
Here's an excellent photo of one built by Mr. Okrasa. The oil switch fitting goes to the upper part of the filter, the lower fitting is the drainback line to the crankcase and comes out of the bottom of the filer housing _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Posted: Wed May 25, 2016 4:56 pm Post subject: Re: Fram oil filter question |
interesting. The one that is to the right of the distributor on mine id coming out about halfway up the generator stand. Right below the casting number |
Posted: Wed May 25, 2016 9:48 pm Post subject: Re: Fram oil filter question |
Same result wherever it is on the top of the case. Having the location below the filter housing will definitely help since it's a drain back. These weren't factory so people could have drilled the case anywhere they wanted _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Wed May 25, 2016 11:22 pm Post subject: Re: Fram oil filter question |
Jasonmorris wrote: |
Porsche did that so maybe someone copied that set up.
A '54 356 case I used to own
_________________ How to Post Photos
Posted: Thu May 26, 2016 12:18 am Post subject: Re: Fram oil filter question |
Ultramoron wrote: |
Here's an excellent photo of one built by Mr. Okrasa. |
I'm pretty sure this one is done with a "hollow stud" on the distributor clamp...so the case isn't drilled _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
