Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Tue May 24, 2016 8:13 pm Post subject: Help me buy carbs and not get burned please |
First off thank you for looking at my thread. I have purchased several sets of used carbs over the years and each time I have paid 4 or 5 hundred bucks for a pair that was supposed to be in good shape but they have turned out to be less than usable. Most ads state the carbs are in good shape, well, that has proven to be false ime. So I end up paying about double after having them rebuilt by people that do an ok job but still not perfect. I know I can buy new made in India/Brazil and assembled in the usa ones but I am stubborn and want to have real Italian ones. So I am asking the good folks here to help me make a better decision this time. I'm not trying be cheap, I don't have the 80's price mentality that I see folks using still ie. trying to cobble a engine together and pay peanuts then flip it to some poor sucker. I just want to end up with something good without being jerked around. If I have to buy new, what should I get, even though it bugs me to run anything Chinese or whatever. These are for a bay bus with a standard type 4, which btw is also costly and iffy ime. Thank you for your help. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Tue May 24, 2016 8:40 pm Post subject: Re: Help me buy carbs and not get burned please |
what are you looking for Dellorto's?? weberIDF's?? weber IDA's?? DCNF's??
I have all avail. |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Tue May 24, 2016 9:03 pm Post subject: Re: Help me buy carbs and not get burned please |
I also have 36, 2 x 40, 45, and a 48 complete bolt on kit in Dellorto for sale as well. All mine tested and fully rebuilt. What is your application, budget, and needs?
Lots of new sets need the basic procedures to ensure proper operation.
So u can choose new and go thru that new set, buy used go thru and take your chances, or buy rebuilt that's tested. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Tue May 24, 2016 9:08 pm Post subject: Re: Help me buy carbs and not get burned please |
There is nothing wrong with the Made in Spain Weber carbs. They are not copies, they are not reproductions, they are real Weber carbs made by the real Weber company. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Tue May 24, 2016 9:20 pm Post subject: Re: Help me buy carbs and not get burned please |
I want to try the webber 40 idf's this time. I have them on my 1904 stroker motor and even though they are worn out, they are easy starting, run smooth and havn't been an issue for me. The dells I have are all ok but needed all the rejetting and venturis and fiddle farking with them even after one of the good guys here rebuilt them. I paid 500 bucks for a so called good set from a guy here that never posts in the forums, he just sells stuff, but he isn't trust worthy ime. Then after another 500 bucks to be rebuilt, they were still not good, meaning the throttle plates were not closing tight and I had to adjust the shaft in in one until it was closing good. I'm hoping to spend my hard earned money once not twice this time. Budget, I don't know, 4 to 5 hundred? Application is a 79 bay with a type 4 stock motor. I have cars with dual ict's, dual webber 40 idf's, dual dellorto 40's, and one with drla's . I am not worried about jetting and syncing them, that's never a problem because I have the books and come here often for answers. And Spanish webers are fine in my head too btw. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
Posted: Tue May 24, 2016 9:32 pm Post subject: Re: Help me buy carbs and not get burned please |
1000 for Dell 40s and rebuilding charge. That's steep. I can't blame you for feeling once bit, twice shy. Imo the dell's are superior, to its brother idf when rebuilt, set up right and with the correct jetting/venturi set. That's my personal opinion. Every carb brand and model has its particulars. However, you have to go with your gut. Good luck and let's hope u get an apple and not a lemon!
Jon _________________ 2276 IDA's 86C 11-1 DD !
modok Samba Member
Posted: Tue May 24, 2016 9:50 pm Post subject: Re: Help me buy carbs and not get burned please |
Red Fau Veh wrote: |
First off thank you for looking at my thread. I have purchased several sets of used carbs over the years and each time I have paid 4 or 5 hundred bucks for a pair that was supposed to be in good shape but they have turned out to be less than usable. |
Guys list carbs for sale as "good", "ok, needs rebuild", "for parts", or my favorite, simply USED
And you know what? It has no relation to reality, at all LOL
Because, people are crazy. They don't know what they have.
If you try to buy something ready to bolt on and go in that price range you probably will be let down.
a few hundred less price range, what you will get is the same, but they sellers probably just have a more "glass is half empty" opinion. The "I rebuilt it wrong myself" guy rather than the "I paid somebody else to rebuild it wrong" guy.
buy low, sell high, expect lemons and get pie!
there is only two levels of quality IMO, used, and blueprinted/tested. Either they are ready to run, or they aren't, but people get all kinds of different ideas. If you EXPECT them to be no more than rebuildable, half the time you'll be pleasantly surprised |
sled Samba Member
Posted: Tue May 24, 2016 10:17 pm Post subject: Re: Help me buy carbs and not get burned please |
As stated above, there is nothing wrong with Spanish carbs, and the reality is they are better than most Italian carbs because they are new and not worn/corroded.
Not get burned? Buy a set of 40 idfs from John at www.aircooled.net and pay him to set them up for you (clean inspect set floats etc).
Simple. _________________ drive your split. |
Posted: Tue May 24, 2016 11:11 pm Post subject: Re: Help me buy carbs and not get burned please |
Cool, that helps me a lot. I forgot I also have a set of the Kadrons on a 1776 rebuilt by a famous Kaddie guy and to be fair, those were bolt on and rock out. But they are just to small and limited imo so I feel I should have gone bigger that time. I will give John a call, he did the rebuild on the drla 36's so I know him. Out of curiosity, I remember hearing new ida 48's are being overhauled when new by someone, maybe CB performance? Something about flaws from the manufacturer needing to be ironed out. Is that still the case or am I just crazy? Oh and are those Decade carbs worth a hill of you know what? Thanks again gents. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7220 Location: Videbaek Denmark
Posted: Wed May 25, 2016 12:32 am Post subject: Re: Help me buy carbs and not get burned please |
Sounds like you have run into half the guys that claim they know about carb rebuilding and tuning.
One of the best in the game of rebuilding carbs is Blackline Racing, also in SLC. I am not aware that ACN does rebuilds, but they set up new carbs to customers needs.
BUT, mind you, it is IMPOSSIBLE to set a set of carbs up to be perfect for a given engine out of the box. They can be set up to be really close. The last fine tune has to be done on the engine. If it happens to be perfect it is a very lucky shot.
T |
Dale M. Samba Member
Posted: Wed May 25, 2016 8:07 am Post subject: Re: Help me buy carbs and not get burned please |
Get out of the Weber- Dell- USED - mentality.... Best carbs right now and NEW are HPMX 40' and pricing new is about what you are going to pay for used Webers or Dels...
Each....
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13-47-1010
$436 for a pair and free shipping (as of May 25-2016) , what is not to like...
dsrtfox Samba Member
Posted: Wed May 25, 2016 8:35 am Post subject: Re: Help me buy carbs and not get burned please |
Or you can buy new HPMX from Blackline. They will set them up on a running engine. You just bolt them on and do final jetting... |
Posted: Wed May 25, 2016 8:36 am Post subject: Re: Help me buy carbs and not get burned please |
We don't do carb rebuilds, we actually won't even touch a carb we aren't selling or have sold. It's rare that a carb is returned for a defect, because that means we didn't catch it prior to shipping.
I do think our setup/jet is a fantastic value, and saves buyers a ton of setup time.
Blackline is the rebuilder we recommend. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Wed May 25, 2016 2:58 pm Post subject: Re: Help me buy carbs and not get burned please |
The OP said he doesn't want Chinese so that eliminates the EMPI HPMX
I think your best dollar value is new Weber IDF's from aircooed.net and pay the extra to have them set up then your done spending. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Wed May 25, 2016 6:55 pm Post subject: Re: Help me buy carbs and not get burned please |
... If I have to buy new, what should I get, even though it bugs me to run anything Chinese or whatever. These are for a bay bus with a standard type 4, which btw is also costly and iffy ime. Thank you for your help. |
He did not say Chinese was totally unacceptable... But if I were him, its either new Webers or Chinese HPMX.... Since his experiences with used and/or "other" types of carbs have been bad, he has little choice...
mark tucker Samba Member
Posted: Wed May 25, 2016 7:06 pm Post subject: Re: Help me buy carbs and not get burned please |
by new, and be prepared to tune them. |
richparker Samba Member
Joined: November 24, 2011 Posts: 6986 Location: Durango, CO
Posted: Wed May 25, 2016 7:11 pm Post subject: Re: Help me buy carbs and not get burned please |
Oh Red...Just buy the new Spanish IDFs with the CB linkage and be done with it. In getting 22-23 mpg in my westy with them, there's no worries man. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Wed May 25, 2016 9:30 pm Post subject: Re: Help me buy carbs and not get burned please |
Max Welton wrote: |
That's Art, right?
Max |
his old company I believe..
thought Art sold it and retired a few years back.. |
Hustlers67 Samba Member
Joined: September 21, 2011 Posts: 263 Location: Sydney, Australia
Posted: Wed May 25, 2016 10:36 pm Post subject: Re: Help me buy carbs and not get burned please |
An extension to the OP - once you have found some that appear good - what next? So as far as setup goes. Are there particular tests that could be done prior to bolting on and hoping for the best?
For example (here comes the hijack) I have dell 40s. taken them apart, put a gasket kit through them (checked the float etc. as per the dell book) - they were pretty good to begin with. I have researched jetting based on my engine and have it pretty close there too. Problem is I dont have an engine to test them on ... only my new engine which I plan on breaking in (not breaking!!). I am scared.
I was thinking of taking them off the manifolds, hooking them up to a fuel line, then gravity feeding fuel into them to see how it all squirts back out. I dont know what else to do to check they will operate - am I being paranoid ? |
