kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2867 Location: Auckland, New Zealand
Posted: Tue May 24, 2016 5:44 pm Post subject: Flasher electrical problem |
I have a weird and frustrating electrical problem with the flasher on the Right front of my car - a RHD '68 Ghia Coupé. When I pull the light switch to the first stop, the following lights light up:
Dash instruments
Green light in Speedo (for low beam)
Rear flasher lights
Number plate light on rear
LEFT FRONT FLASHER (indicator) - But not the RIGHT front flasher - There lies the problem.
At the second stop on the light switch, the flashers are off but the lights come on, as they should. Low beam and high beam work.
When I pull the emergency flasher switch, the flashers all round flash (blink, as they say in German), including the RIGHT front flasher.
The turn signals work, including on the RIGHT front flasher (indicator light).
All the fuses are good.
Please help. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Tue May 24, 2016 6:51 pm Post subject: Re: Flasher electrical problem |
Ok. First I think we need to bring our language in balance. when you pull the light switch to first notch, It turns on the 'running lights'(US). The front bullets have a dual filament bulb, one for 'running light' -one for the 'blinker' or flasher, which is brighter. So the problem is not in the 'blinker' loop ,all four work.
Here is a chart:
http://www.thesamba.com/vw/archives/info/wiring/ghia_67_USA.jpg
The light switch here is marked 'F' . Just to the left, You will see a split connector marked 'T'. Check the wire connection there. The left side circuit is fine but the right could be loose. Those wires run uninterrupted till they reach the bullet housing. So you want to check the connection there as well. The bullet housing must have a good ground since the flasher works.The black/green/white wire is the flasher line, Grey the driving light. Really that looks like the only possible points of malfuction. Pull the cover of the left bullet so you can see and understand how the dual filament bulb operates.
Let me know if that makes sense...... |
Posted: Tue May 24, 2016 7:46 pm Post subject: Re: Flasher electrical problem |
Thank you, swavananda. I've been following your posts on matters electrical and was hoping you'd be the first to respond.
I checked everything in the order you suggested and found the fault right at the last part. The bulb didn't make clean contact.
Clear advice: Problem solved. Case closed. Thank you. _________________ Festina lente - hasten slowly
Posted: Tue May 24, 2016 8:41 pm Post subject: Re: Flasher electrical problem |
Sometimes it that easy ! Since you are near/in the middle of the ocean, You might look into dabbing Conductive grease(not dielectric) on your bulb connections and any others that may act up because of salt corrosion |
Posted: Tue May 24, 2016 9:42 pm Post subject: Re: Flasher electrical problem |
swavananda wrote: |
Sometimes it that easy ! Since you are near/in the middle of the ocean, You might look into dabbing Conductive grease(not dielectric) on your bulb connections and any others that may act up because of salt corrosion :wink: |
I'll do that for sure, thanks (The Pacific is visible from my window as I write this, no more than 5-600 yards or so. So corrosion is an ever-present enemy.) _________________ Festina lente - hasten slowly
