VW&MGman Samba Member
Posted: Mon May 23, 2016 12:21 pm Post subject: 1.4 Scat Rocker Arm Pitting |
Hi Everyone,
Has anyone every experience pitting on the rocker arm faces, that contact the lash cap on Scat 1.4 rocker arms?
I installed the set of lash caps that came with the Scat 1.4 kit, and after approximately 10 miles of engine break-in, I adjust the valves, and I found one of the lash caps 'concaved' and a few others badly pitted. The rockers were pitted as well.
I'm running DRD L6 heads with their valve springs and chromoly push rods. Clearance was set to 0 loose.
Any thoughts or suggestions? |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Mon May 23, 2016 12:33 pm Post subject: Re: 1.4 Scat Rocker Arm Pitting |
Aren't SCAT ratio rockers heat treated on their tips? Is the metal a different color there? If not, maybe they skipped treatment. |
Posted: Mon May 23, 2016 12:42 pm Post subject: Re: 1.4 Scat Rocker Arm Pitting |
The metal is the same color. |
mark tucker Samba Member
Posted: Mon May 23, 2016 1:22 pm Post subject: Re: 1.4 Scat Rocker Arm Pitting |
did you use any moly cam lube inbetween the lash cap&the rocker foot? do you have enough oil supply to them? the oe oiling is just a spirt&squirt at best.also is the geo right? |
theDrew Samba Member
Posted: Mon May 23, 2016 1:47 pm Post subject: Re: 1.4 Scat Rocker Arm Pitting |
Geometry is correct, and I'm using Valvoline VR1 oil.
I would assume that there is enough oil, as when I take off the valve cover, everything is oily.
I tried capturing a picture of the damage, but is it not coming out clear. |
jason Samba Member
Posted: Mon May 23, 2016 2:14 pm Post subject: Re: 1.4 Scat Rocker Arm Pitting |
You check coil bind, max lift and valve to piston clearance? |
Posted: Mon May 23, 2016 3:13 pm Post subject: Re: 1.4 Scat Rocker Arm Pitting |
Hi Jason,
Yes, coil bind, valve clearance has all been checked at assembly. |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Mon May 23, 2016 4:46 pm Post subject: Re: 1.4 Scat Rocker Arm Pitting |
If they show no signs of being heat treated, and have rapid wear in 10 miles...... call Scat and explain the situation.
Screw-ups do happen, I'm sure 75% of the complaints they get are stupid baloney from people that don't know what's going on, but if there is a real problem you should tell them, and they might even give you another set. |
Posted: Mon May 23, 2016 5:46 pm Post subject: Re: 1.4 Scat Rocker Arm Pitting |
I just called Tom at Scat...he is to look into it.
Let's see what happens. |
Posted: Tue May 24, 2016 12:38 pm Post subject: Re: 1.4 Scat Rocker Arm Pitting |
you can also do a file test. as for the vr1......so you didnt use moly on them.just because there is oil in the area dosent mean it's getting where it needs to be when it needs to be there. |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Tue May 24, 2016 8:50 pm Post subject: Re: 1.4 Scat Rocker Arm Pitting |
Here's a photo of my Scat 1.4 rockers for comparison and you can see the flame-hardened tips:
_________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Howard 111 Samba Member
midtravelmidengine Samba Member
Joined: August 06, 2009 Posts: 861 Location: Riverside, Ca
Posted: Wed May 25, 2016 8:18 am Post subject: Re: 1.4 Scat Rocker Arm Pitting |
Howard 111 wrote: |
Good photo Neil. |
X2 _________________
modok wrote: |
And I know you don't know because if you did you would know the reason for my knowing you didn't. |
youngnstudly wrote: |
I just wasn't sure if I should recommend the 1/3 race cam, the 1/2 race cam, or the 5/8 race cam instead...guess it depends on how much of the race he wants to lead???
Posted: Wed May 25, 2016 10:31 am Post subject: Re: 1.4 Scat Rocker Arm Pitting |
next question....do they say scat on them like the ones neil posted there are many out there that look similar but arnt. I bought a set of the look alikes and found all kinds of shit not right including not heatreeted, tips not square to the shaft&more. I fied them and heatreeted them and have around 35000 miles on them. with out the fix they went about 100 miles.Ive since bought another set , reworked them and they have about 75000 miles. |
Posted: Wed May 25, 2016 4:59 pm Post subject: Re: 1.4 Scat Rocker Arm Pitting |
Hi Neil,
Yes mine do say SCAT on the rockers and are 'blued' on the ends of the rocker. They look very similar to yours.
I'm thinking that the lash caps are the root cause of this issue. I spoke with SCAT and I'll be sending them the lash caps for them to analyze.
When your rockers are installed and adjusted on your engine, approximately how many threads are exposed on adjusting screw? |
Posted: Wed May 25, 2016 5:29 pm Post subject: Re: 1.4 Scat Rocker Arm Pitting |
As long as they are blued on the ends, they should be okay. The blued look means they were flame hardened, a needed process to make them last. _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
neil68 Samba Member
Posted: Wed May 25, 2016 7:09 pm Post subject: Re: 1.4 Scat Rocker Arm Pitting |
VW&MGman wrote: |
Hi Neil,
Usually 2-3 threads are exposed outside the nut:
jason Samba Member
Posted: Thu May 26, 2016 8:02 pm Post subject: Re: 1.4 Scat Rocker Arm Pitting |
I read the Scat lash caps were soft. I read it on here but can't remember where. |
neil68 Samba Member
Posted: Thu May 26, 2016 9:23 pm Post subject: Re: 1.4 Scat Rocker Arm Pitting |
I've used a set of Scat lash caps for ~10 years with no issues. Then last week, one broke in half on my first drag race of the season:
