Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Sat May 28, 2016 11:31 am Post subject: Re: Fastback fuel injection project |
That is indeed the wire for the oil pressure sender. What's that wire you have hooked up to yours? It looks like it might be the one for the kickdown switch. _________________ 71 Elm Green FI A/T Squareback |
t-royR Samba Member
Joined: April 19, 2012 Posts: 464 Location: Minnesota
Posted: Sat May 28, 2016 11:39 am Post subject: Re: Fastback fuel injection project |
Here is another photo. If you have advise on what wires to switch, please give. Which part is the kickdown, and I don't see where the oil sensor is at
_________________ T-roy
75 Super
71 Super
71 Ghia coupe auto-stick
71 Ghia conv
69 Fasty
74 Ghia conv |
stonecoldcars Samba Member
Joined: February 21, 2013 Posts: 265 Location: Oregon
t-royR Samba Member
Posted: Sat May 28, 2016 12:00 pm Post subject: Re: Fastback fuel injection project |
thanks. Any idea where that black wire I currently have connected, is supposed to go? It comes from the tranny area. I fed it over the front tin on engine install, thinking it connects to something in the engine bay. Perhaps it connects to the tranny somewhere?
What about that little white wire that is not connected? The one right above oil sensor you pointed out, assuming that is the sensor, and not the kickdown. _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
Posted: Sat May 28, 2016 12:24 pm Post subject: Re: Fastback fuel injection project |
t-royR wrote: |
What about that little white wire that is not connected? The one right above oil sensor you pointed out, assuming that is the sensor, and not the kickdown. |
The black wire goes down to the transmission and plugs into the kickdown solenoid. The upper end of the wire plugs into the kickdown switch by the intake, but your engine is missing the switch. Here's what it looks like:
Another view (don't mind the red arrow):
No need to worry about that right now, though. Plug the greenish bluish wire into the sender.
The white wire is part of the injection wiring harness. I don't know where that wire goes on a 69 system. I'm sure someone will be along shortly to tell you. _________________ 71 Elm Green FI A/T Squareback
Last edited by Donnie strickland on Sat May 28, 2016 12:29 pm; edited 1 time in total |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sat May 28, 2016 12:26 pm Post subject: Re: Fastback fuel injection project |
t-royR wrote: |
Oil sensor wire will be a blue green. The black wire is to the trans side of the kick down switch. The other end of the kick down switch gets power from the + (key) side of the coil and should have an inline fuse.
The white wire you are asking about I believe goes to Temp Sensor 2, the head sensor. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17969 Location: Eugene, OR
Posted: Sat May 28, 2016 12:33 pm Post subject: Re: Fastback fuel injection project |
My fused wire goes to the kickdown switch.
_________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sat May 28, 2016 12:42 pm Post subject: Re: Fastback fuel injection project |
On my 71, the fuse is between the coil and the switch, which matches the wiring diagram:
But as I say, that doesn't matter right now, since his switch is missing. _________________ 71 Elm Green FI A/T Squareback |
Posted: Sat May 28, 2016 12:47 pm Post subject: Re: Fastback fuel injection project |
t-royR, can you show us a picture of the wiring on your coil, and the wire on the head temperature sensor? _________________ 71 Elm Green FI A/T Squareback |
t-royR Samba Member
Posted: Sat May 28, 2016 3:50 pm Post subject: Re: Fastback fuel injection project |
couple shots of the coil _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
t-royR Samba Member
Posted: Sat May 28, 2016 4:03 pm Post subject: Re: Fastback fuel injection project |
where is the head temperature sensor? _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
t-royR Samba Member
Posted: Sat May 28, 2016 4:43 pm Post subject: Re: Fastback fuel injection project |
Could this oil temp sensor mis-wire I had in place have been the cause, or part of the cause, for my issues getting the car to start? I believe I have the sensor correctly wired now, from the earlier advise. _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
Posted: Sat May 28, 2016 6:08 pm Post subject: Re: Fastback fuel injection project |
t-royR wrote: |
Could this oil temp sensor mis-wire I had in place have been the cause, or part of the cause, for my issues getting the car to start? I believe I have the sensor correctly wired now, from the earlier advise. |
The sensor wire wouldn't figure in that, no.
See that black wire with the inline fuse, coming off the coil? That would go to your kickdown switch, and the black wire we pointed out earlier would go to the second terminal on the kickdown switch. Don't let this wire (coming from the coil) touch bare metal. In fact, you could go ahead and remove it since you don't have a kickdown switch.
The temp sensor should be on the left side head, towards the rear as you look down at the top of the head. _________________ 71 Elm Green FI A/T Squareback |
t-royR Samba Member
Posted: Sat May 28, 2016 6:32 pm Post subject: Re: Fastback fuel injection project |
That black wire with the inline fuse goes to the head sensor. It looks to belong there as it has a very unique cable and is attached directly to the sensor (no way to disconnect from the sensor).
Could it be that the white wire is supposed to connect to that sensor on the air intake body, instead of the black wire(s)? It seems to be the only place that white wire will reach, and the wire comes from the same wire grouping that connects to the other sensors for the fuel injection black box? _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34002 Location: Conejo Valley, CA
Posted: Sat May 28, 2016 6:54 pm Post subject: Re: Fastback fuel injection project |
t-royR wrote: |
That black wire with the inline fuse goes to the head sensor. It looks to belong there as it has a very unique cable and is attached directly to the sensor (no way to disconnect from the sensor). |
The head sensor wire has no fuse. It ends in a female push-on terminal. That terminal fits into a T1 connector (clear plastic, now probably yellow with age or brown with dirt and heat), but there is no fuse in it.
White FI wires have wire numbers inked on them. Clean it and look for a number. We can then tell where it should connect. |
Posted: Sat May 28, 2016 6:58 pm Post subject: Re: Fastback fuel injection project |
t-royR wrote: |
That doesn't sound right. Could you check it again? If that black wire is connected to the temp sensor, it's no wonder the car won't run.
You are correct that the temp sensor wire won't disconnect from the sensor. It's made that way. If that wire isn't plugged in, the car won't run.
Here's my temp sensor wiring. See the orange arrow pointing to the sensor? And the yellow arrow pointing to the white wire you're wondering about? Now look up by the end of the generator. See the plastic connector? That's where the two wires join. The connector has two male ends inside, so you can join the two female wire ends together.
t-royR Samba Member
Posted: Sat May 28, 2016 7:07 pm Post subject: Re: Fastback fuel injection project |
the black wire with the inline fuse runs down to the right of the distributor, and under the engine where it is a solid connection to some sensor (I assume it is a sensor). This is on the left side (under side) of the engine, when looking from behind. Again, that is the black wire coming off the coil, with an inline fuse. The other black wire (actually, blue under the plastic cover) that I originally indicated was disconnected, comes from a wire grouping that comes out of the left side of the engine wall, with the wires that connect to the coil. _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
KTPhil Samba Member
Posted: Sat May 28, 2016 7:14 pm Post subject: Re: Fastback fuel injection project |
t-royR wrote: |
the black wire with the inline fuse runs down to the right of the distributor, and under the engine where it is a solid connection to some sensor (I assume it is a sensor). This is on the left side (under side) of the engine, when looking from behind. Again, that is the black wire coming off the coil, with an inline fuse. |
The only wire coming from the coil with a fuse holder on an automatic car is for the kick down switch at the throttle plate. If it is connected anywhere else it will cause problems. |
t-royR Samba Member
Posted: Sat May 28, 2016 7:32 pm Post subject: Re: Fastback fuel injection project |
pic of sensor line with fuse plugs into, under engine
better pic of wire with in-line fuse, where it can be seen that it runs down to below the engine. Has some connector just before it goes through the bottom tin piece.
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
