B+ wire smoked from generator to regulator
loqutus99
loqutus99 is offline
PostPosted: Mon May 23, 2016 6:01 am    Post subject: B+ wire smoked from generator to regulator Reply with quote
The B+ wire going from the generator to the voltage regulator completely cooked the insulation off the wire. I replaced all the wires on the regulator and the B+ wire still got hot. I disconnected the wire as I was trying to get the idle working and the generator seems excessively hot. Any ideas or suggestions?
Multi69s
Multi69s is offline
PostPosted: Mon May 23, 2016 12:04 pm    Post subject: Re: B+ wire smoked from generator to regulator Reply with quote
It is possible that the regulator is stuck open causing the gen to charge wide open. Could also be a short in the regulator. Open it up and look for any loose / broken pieces, or points that are welded closed.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
loqutus99
PostPosted: Mon May 23, 2016 12:28 pm    Post subject: Re: B+ wire smoked from generator to regulator Reply with quote
This is one of the new style Voltage regulators, solid state and it is brand new. I have taken the generator off and going to have it rebuilt. If the wire going to the idiot light is grounded out will that cause the issue I am having?
loqutus99
PostPosted: Mon May 23, 2016 12:41 pm    Post subject: Re: B+ wire smoked from generator to regulator Reply with quote
Just a point to add, this is on a 1967 Dune Buggy. I have enclosed the voltage regulator in a plastic conduit box with the 5 wires coming out of the box. B+, DF, 61 going to the idiot light, power (red) wire going to the starter (Battery 12v) and the ground wire attaching to the bolt holding the generator plate to the fan shroud.
Docbar
Docbar is offline
PostPosted: Sat Jun 04, 2016 1:02 pm    Post subject: Re: B+ wire smoked from generator to regulator Reply with quote
I have been dealing with the same issue . Voltage at battery read 17 volts at approximately 2000 RPM swapped out the voltage regulator and noe reads 13.5 at same RPM and all is good hope this helps ps this was with a brand new Bosch solid state regulator must have been bad out of the box
