igtoth Samba Member
Joined: May 09, 2006 Posts: 385 Location: Ribeirão Preto, SP, Brazil
Posted: Fri May 20, 2016 10:37 am Post subject: Gasoline fuel line question |
I'm replacing the gasoline fuel line, and the one I removed is copper. Is this correct ??? _________________ 1957 Typ 113 - Polarsilver
1959 Typ 113 - Flint Grey
1975 Typ 221 - Last yr Brazilian Split Window
Ighor Toth |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Fri May 20, 2016 1:20 pm Post subject: Re: Gasoline fuel line question |
It's probably not copper. Stock is copper plated steel. Have you tried a magnet on it?
If it is copper, it should be replaced with steel. |
igtoth Samba Member
Posted: Fri May 20, 2016 1:21 pm Post subject: Re: Gasoline fuel line question |
nlorntson wrote: |
You're right, its copper plated steel.. Thanks! _________________ 1957 Typ 113 - Polarsilver
Ighor Toth |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Fri May 20, 2016 5:27 pm Post subject: Re: Gasoline fuel line question |
EverettB wrote: |
I can't recall if this was asked and answered before but why did they use copper-plated steel and not just a steel line like the brake lines?
Does the copper dissipate engine compartment heat better or ? |
I've wondered that too, I was thinking more for corrosion resistance. Maybe higher stakes danger if a fuel line fails? |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Mon May 30, 2016 9:31 am Post subject: Re: Gasoline fuel line question |
Corrosion resistance. Probably at the time copper was the less expensive way.
Even solid metal brake lines today are coated one way or another to keep corrosion away for as long as possible and at same time to keep down final cost.
https://duckduckgo.com/?q=solid+brake+lines+are+coated&t=canonical&ia=web _________________ In Stereo, Where Available! |
igtoth Samba Member
Posted: Mon May 30, 2016 4:00 pm Post subject: Re: Gasoline fuel line question |
I just installed a new stainless steel fuel line. Hopefully this can make more 60yrs. _________________ 1957 Typ 113 - Polarsilver
Ighor Toth |
