schwartzkafer Samba Member
Posted: Wed May 18, 2016 1:39 pm Post subject: Steering column |
Does anyone know if the steering shaft from a 1956 T1 is the same length/diameter as the 1960s T1? I know the splines are not going to be the same, but I am using an aftermarket steering wheel, so that doesn't bother me. Just need to know if I can swap one for the other. |
EVfun Samba Member
Posted: Wed May 18, 2016 4:08 pm Post subject: Re: Steering column |
Starting with 1960 the steering column got a little shorter to accommodate the new dished steering wheel. The turn signal switch was completely different starting that year too. _________________
Wildthings wrote: |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Wed May 18, 2016 4:51 pm Post subject: Re: Steering column |
schwartzkafer wrote: |
1960 and later shafts ARE shorter in length, same diameter and all 1956 and later splines are the smooth type, same.... you can use a later column with the later style directional indicator switch, as mentioned _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
