J.Adam Samba Member
Posted: Tue May 17, 2016 8:55 pm Post subject: 1976 baja bug |
Hi, I'm pretty new to cars and particularly VW's but I am really interested in buying a 1976 beetle that is already a built baja bug. I just don't know if this is a good year of beetle to make it baja or basically anything about this stuff. Something that I have read about (because it looks like it could be one of the most costly expenses) is the difference between Independent Rear Suspension and a swing axle. From what I've read it takes a lot of fabricating to convert a swing axle to an IRS, the only reason I would do that is because it appears that an IRS would be a better option for a baja bug; but again, I don't know anything about this stuff so I don't know if that matters. Anything you guys could offer to help me out on this would be great. |
dustymojave Samba Member
Posted: Tue May 17, 2016 10:52 pm Post subject: Re: 1976 baja bug |
a 1976 came with IRS rear suspension.
The front in a '76 is ball joint, unless it's been converted to king pin (or even a-arm) on the car you're considering buying. Ball joint will work OK for mild offroad use.
So the next step is photos. Link to an ad or something so we can offer some advice. If we can't see what you're asking about, we can't help.
One of the biggest problems with a a 76 Baja in California is getting it past smog inspection. Right now, a 75 or older doesn't require smog inspection. A '76 DOES. _________________ Richard
SoCalBajas Member
weasel_ugs Samba Member
Joined: March 16, 2012 Posts: 721 Location: Prescott Valley,Az.
Posted: Thu May 19, 2016 5:57 pm Post subject: Re: 1976 baja bug |
Actually a '76 should be coil front and IRS rear. Although the mexican bugs could be swing axle rear and king pin front. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8689 Location: Sunset, Louisiana
Posted: Fri May 20, 2016 8:16 am Post subject: Re: 1976 baja bug |
weasel_ugs wrote: |
That would be correct for a Super, but not for a standard. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Fri May 20, 2016 1:39 pm Post subject: Re: 1976 baja bug |
weasel_ugs wrote: |
Only Super Beetles EVER came from the factory with coils in front. All standard Beetles after about 1966, worldwide came with ball joint front suspension. No matter WHAT market. On the rear, many Beetles in markets other than the USA, were equipped with swingaxle, all the way through the very last Beetle produced in Mexico in 2003. But just because they were swingaxle, does not mean they had linkpin front end. _________________ Richard
SoCalBajas Member
