kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1160 Location: Woodstock, NH
Posted: Sun May 15, 2016 1:47 pm Post subject: '78 FI westy won't start |
Trying to type this on my phone please be patient.
Was driving my 78 today everything was fine parked it. Went out to drive it again and clutch made funny noise. Figured it was the clutch cable. Luckily I had a spare.
New cable installed, then mini test, clutch feels like butter now, I didn't realize how bad the frayed cable was dragging.
The test was basically back upba couple feet then forward a couple feet.worked fine. Time to clean up.
After clean up - bus won't start. Won't even turn over. I hooked up a battery jumper still will not turn over. I disconnected wires to solenoid and cleaned up those connections still won't start.
I tried shorting connection at solenoid- with key in On position and nothing.
All dash lights come on normally when trying to start, just won't turn over at all. Checked fuses- all look OK.
I checked the forum - and not sure what to do next? Any suggestions?
Oh yeah, I'm not at home. About 5 miles from there. Not sure if I should tow home or tow to shop. Would prefer simple fix here. _________________ -Kevin
Lincoln, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper |
MaritimeBay Samba Member
Joined: September 16, 2013 Posts: 120 Location: Fredericton NB
Posted: Sun May 15, 2016 2:56 pm Post subject: Re: '78 FI westy won't start |
I ran in to a similar issue just the other day when starting the bus for the first time after the winter. It turned out to be poor connection at the battery. Cleaning up the battery posts and making sure the cables were on there tight was the fix.
In your case though, is it possible that the transmission to body ground strap has a poor connection or was moved around a little bit while you were under there replacing the clutch cable? _________________ 1977 2.0L FI Westfalia.
They call my home the land of snow. |
Posted: Sun May 15, 2016 3:08 pm Post subject: Re: '78 FI westy won't start |
I had checked the ground strap, and looks OK.
I notice when I hook the jumper battery up, the dash lights get super bright - and I still get nothing out of bus.
I'll double check ground strap - but if this was loose, wouldnt I get something from starter? Even a weak turning over? When I turn key I don't even hear fuel pump starting up. _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sun May 15, 2016 3:25 pm Post subject: Re: '78 FI westy won't start |
If nothing else, a push start should get you home. Is there 12v to the coil in "On" position? _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun May 15, 2016 3:40 pm Post subject: Re: '78 FI westy won't start |
Have a look up under the base of the steering column at the wires that plug into the back of the ignition switch and confirm that plug hasn't worked loose.
But that wouldn't cause no action when jumping the terminals directly on the starter, my vote is for bad battery terminal or cable, "looks OK" isn't good enough, remove each connection and mess around with it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun May 15, 2016 3:45 pm Post subject: Re: '78 FI westy won't start |
Unfortunately I don't have a meter with me, and push start from where it is parked is near impossible.
I'm starting to think something is wrong with the starter. I think I'm going to get it towed to my house AAA, then try my multimeter to check voltage at coil. _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Posted: Sun May 15, 2016 3:58 pm Post subject: Re: '78 FI westy won't start |
Just to add to what was said above - I had a 'bad' positive cable (corroded on the inside) a couple years back with similar symptoms as well; dash lights come on -> turn key, nothing. _________________ 1977 2.0L FI Westfalia.
Posted: Sun May 15, 2016 5:14 pm Post subject: Re: '78 FI westy won't start |
I cleaned the ground transmission strap and the positive battery strap - no go.
The wire at the underside of the ignition appears to be tight. I get 10.8V at the positive side of the coil.
When I try to start - the dash lights do not dim in the slightest.
If the starter has gone bad - is there anyway to determine that, short of removing it from the vehicle, and bringing it somewhere to have it tested? _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Posted: Sun May 15, 2016 5:28 pm Post subject: Re: '78 FI westy won't start |
Just remember, it can't be run out of the bus because the bushing that supports the armature properly is in the bell housing. _________________ If you haven't bled on them, you haven't worked on them.
Posted: Sun May 15, 2016 5:36 pm Post subject: Re: '78 FI westy won't start |
I thought you could bring it to a place that works on starters - and they could test it for you? Or most FLAPS always have a sign up that says they will test your starter or battery? or am I remembering that wrong?
Forgot to ask - as far as jumping the starter connections - I have done this before on my older bus ('65). Now this '78 is FI, and I am wondering if maybe I am not doing the jumpber correctly. Could someone clarify how to do this?
I think if I do the 'jumper' at the starter, and get nothing - I either have a bad wire from the battery, or a bad starter, right? _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Sun May 15, 2016 6:16 pm Post subject: Re: '78 FI westy won't start |
kguarnotta wrote: |
I think if I do the 'jumper' at the starter, and get nothing - I either have a bad wire from the battery, or a bad starter, right? |
Have you removed the terminals from the battery posts? Clean the posts and the inside terminal circles.
Colin _________________ www.itinerant-air-cooled.com |
Posted: Sun May 15, 2016 6:30 pm Post subject: Re: '78 FI westy won't start |
Yeah I did that. Took the battery terminals off and cleaned them, but it wouldn't start even with the jumper attached to the battery connections. (which basically takes the battery out of the loop if it has a bad connection, right?) _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Posted: Sun May 15, 2016 6:39 pm Post subject: Re: '78 FI westy won't start |
kguarnotta wrote: |
Yeah I did that. Took the battery terminals off and cleaned them, but it wouldn't start even with the jumper attached to the battery connections. (which basically takes the battery out of the loop if it has a bad connection, right?) |
Dang, I think we are at the starter . . .
Colin
(who lived in Jamaica Plain in 1977 briefly) _________________ www.itinerant-air-cooled.com |
Posted: Sun May 15, 2016 7:03 pm Post subject: Re: '78 FI westy won't start |
Ok - if it is the starter - I'm looking at a rebuilt Bosch unit - or I see GoWesty makes a Gear Reduction starter. Anyone try one of their starters in a Bay Window Westy - they are a good bit more than a rebuilt bosch. I am wondering about the quality of a rebuilt 35+ year old starter vs a new one - that has been redesigned. _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Posted: Sun May 15, 2016 7:35 pm Post subject: Re: '78 FI westy won't start |
Geez, just realized - forgot to thank you all for your suggestions. Got my head so confused tracking this thing down.
Thanks to all. Keep the suggestions coming.... _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Tcash Samba Member
Posted: Mon May 16, 2016 1:21 pm Post subject: Re: '78 FI westy won't start |
thanks, but I guess with a FI vehicle, there are two smaller wires hooked up to the starter. _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
SGKent Samba Member
Posted: Mon May 16, 2016 1:38 pm Post subject: Re: '78 FI westy won't start |
take a small hammer and tap (not hammer) the solenoid while someone tries to start it in neutral, chock the tires.
Automatic or manual. If an automatic there is also a neutral switch that can fail besides the solenoid stick. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon May 16, 2016 6:23 pm Post subject: Re: '78 FI westy won't start |
I had tried tapping the starter with a hammer - and got nothing, but not with someone starting it.
One question - that makes me think that maybe it is a wiring issue and not a starter issue - when I turn the key, shouldn't I hear something? Ie the fuel pump or something? I don't hear anything. This is FI. _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Posted: Mon May 16, 2016 6:48 pm Post subject: Re: '78 FI westy won't start |
kguarnotta wrote: |
One question - that makes me think that maybe it is a wiring issue and not a starter issue - when I turn the key, shouldn't I hear something? Ie the fuel pump or something? I don't hear anything. This is FI. |
No. Ignition-only is perfectly silent.
