58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Sat May 14, 2016 2:24 am Post subject: Hyd clutch pedal |
does anyone have pics of a pedal setup installed you are using if you convert to ta hydraulic clutch?
thanks _________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project |
Aerindel Samba Member
Joined: May 30, 2015 Posts: 459 Location: Western Montana
Posted: Sat May 14, 2016 12:12 pm Post subject: Re: Hyd clutch pedal |
Nope. Its so simple I never thought to take a picture of it.
You just buy it, bolt it in, run your tubing. Enjoy. _________________ Homemade woods/street, bug out rail. IRS, Balljoint front end. 1967 1600cc DP, Weber 32/36 progressive, tri-mil quiet pack. Rear only cutting brakes.
http://www.thesamba.com/vw/forum/viewtopic.php?t=630046 |
58Dub Samba Member
Posted: Sun May 15, 2016 8:51 am Post subject: Re: Hyd clutch pedal |
So... did you use a complete 3 pedal assembly, or just a single pedal for the clutch? _________________ 58 Beetle (now just a pile of parts in the corner)
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2663 Location: West Coast (Michigan's)
Posted: Tue May 17, 2016 1:38 pm Post subject: Re: Hyd clutch pedal |
58Dub wrote: |
So... did you use a complete 3 pedal assembly, or just a single pedal for the clutch? |
I used a three pedal assembly. _________________ Homemade woods/street, bug out rail. IRS, Balljoint front end. 1967 1600cc DP, Weber 32/36 progressive, tri-mil quiet pack. Rear only cutting brakes.
smileyman3000 Samba Member
Joined: November 07, 2010 Posts: 238 Location: Yeppoon, Australia
Posted: Tue May 17, 2016 5:11 pm Post subject: Re: Hyd clutch pedal |
Hey mate. I am using a stock T3 master in my baja because I am using the T3 5 Speed with the stock hydro clutch setup.
Installed next to the bus master. I had to move it over.
With the pedals I moved the pin over onto the brake pedal. And added a second one on the clutch pedal to push the clutch slave in.
More pictures/etc about a quarter of the way down page 9 of my build.
And then it all assembled is right near the bottom of that page.
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...;start=160
Smiley |
58Dub Samba Member
Posted: Mon May 23, 2016 1:13 am Post subject: Re: Hyd clutch pedal |
smileyman3000 wrote: |
Smiley |
thanks for the pics... that helps me _________________ 58 Beetle (now just a pile of parts in the corner)
3gengines Samba Member
Joined: July 17, 2015 Posts: 73 Location: Sugar Hill, Ga
Posted: Mon May 23, 2016 7:14 pm Post subject: Re: Hyd clutch pedal |
This is what I used.[/img] |
58Dub Samba Member
Posted: Mon May 23, 2016 7:21 pm Post subject: Re: Hyd clutch pedal |
3gengines wrote: |
yes, beautiful stuff..... but a bit out of my budget for now _________________ 58 Beetle (now just a pile of parts in the corner)
dustymojave Samba Member
Posted: Mon May 23, 2016 8:36 pm Post subject: Re: Hyd clutch pedal |
Also takes a fair bit of fabricating to fit it into the VW foot well. _________________ Richard
SoCalBajas Member
Posted: Tue May 24, 2016 3:38 am Post subject: Re: Hyd clutch pedal |
Yeah, I have a rail buggy and I am a fabricator and build race cars on the side, so it's not too bad. I can see where that would be difficult to fit into a bug foot well. I have seen some really nice petal set ups that are pretty reasonable. Mine had a stock set up that worked really well. I changed because I got a really good deal from Wilwood on the petals. Then I had to buy an all new disc brake set up because I had two master cylinders now. My buggy had no front brakes before. Oh well, big boy toys right? |
red caddy Samba Member
Posted: Sun May 29, 2016 6:38 pm Post subject: Re: Hyd clutch pedal |
This was the easiest, cleanest set up I could come up with. A serious PITA to try and fit into a Baja, but perfect for a rail or tube car. _________________ If it turns $$$ into smoke and noise, I'm there.
My last build thread. http://www.thesamba.com/vw/forum/viewtopic.php?t=466571 |
protocox Samba Member
Posted: Tue May 31, 2016 9:12 am Post subject: Re: Hyd clutch pedal |
Hello,
I use single pedal on my towd, one for clutch and one with 2 MC for brake ( 4 discs brake ) all are 3/4 MC.
I install them Under the Hood to reduce the contact with dust/mud
I'll try to take better pictures asap |
Posted: Tue May 31, 2016 11:15 pm Post subject: Re: Hyd clutch pedal |
There is a LOT that I like about your Tow'd. Nice buggy. _________________ Richard
SoCalBajas Member
