ExtremeBean Samba Member
Posted: Thu May 12, 2016 7:24 pm Post subject: How do you guys restore door lock mechanisms hardware? |
I took a wire wheel to it and cleaned them up a bit but was just wondering what the norm is. Do you guys paint them, soak them in degreaser, oil them afterwards, etc?
[img][/img] |
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Thu May 12, 2016 7:41 pm Post subject: Re: How do you guys restore door lock mechanisms hardware? |
Looks like you've stumbled upon the right procedure! A little bit of light grease on the internal bits, and you should be good to go ... Nice work. _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
grandpa pete Samba Member
Posted: Thu May 12, 2016 8:06 pm Post subject: Re: How do you guys restore door lock mechanisms hardware? |
for a thorough cleaning spray the insides with easy off oven cleaner ; this will get all the grease out of the mechanism ; cleaning the outside with a wire brush is a great start . _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
carcrazed Samba Member
Posted: Fri May 13, 2016 12:26 pm Post subject: Re: How do you guys restore door lock mechanisms hardware? |
Nice!! X2 on hitting the mechanisms with some grease and good to go! _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
bluebus86 Banned
Posted: Fri May 13, 2016 4:04 pm Post subject: Re: How do you guys restore door lock mechanisms hardware? |
wire wheel will alter the surface finish, forever change the striker plate texture and remove the zinc plating off the lock mechanism.
It would have been far better to soak them in mineral spirits to clean them and grease as needed. Grease on some surfaces will last longer than oil, originally they were greased. grease in a syringe is useful for getting into tight places.
for restoration, places do re-plate these parts.
a light touch with fine steel wool is better for the striker plate, but make it a very light touch.
now that the latch is stripped of zinc, best to degrease it and rattle can it with some silver paint, then grease the insides. do not load up the insides with paint. your need to paint it as with the zinc plating gone, it will now rust badly _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Sat May 14, 2016 12:48 pm Post subject: Re: How do you guys restore door lock mechanisms hardware? |
LOTS of stuff on YOUTUBE and ebay for diy zinc plating ...... _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
62ItalianRagtop Samba Member
Posted: Mon May 16, 2016 12:58 am Post subject: Re: How do you guys restore door lock mechanisms hardware? |
These parts are made of aluminum, can not be galvanized. _________________ LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/ |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Mon May 16, 2016 8:29 am Post subject: Re: How do you guys restore door lock mechanisms hardware? |
62italian, I've read your build, and I don't doubt your knowledge, but while I think the striker block is solid aluminum, I THINK the door latching mechanism is steel.
Extremebean,
I had a lot of fun setting up a home electroplating kit. Here is the article I found to get me started. Zinc plating is a helluva lot of fun AND inexpensive (and relatively safe).
http://www.southsandia.com/forum/website/zincplating.html _________________ Plate of shrimp |
Posted: Mon May 16, 2016 9:31 am Post subject: Re: How do you guys restore door lock mechanisms hardware? |
I think that a part of door latching mechanism is aluminium _________________ LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
Keith Samba Member
Joined: August 15, 2005 Posts: 3635 Location: Brodheadsville, PA
Posted: Tue May 17, 2016 6:43 am Post subject: Re: How do you guys restore door lock mechanisms hardware? |
Striker is aluminum, the latch assembly is galvanized stamped steel. The rust on the latch is your first clue. Grab a magnet if you doubt it. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Posted: Tue May 17, 2016 8:13 am Post subject: Re: How do you guys restore door lock mechanisms hardware? |
62italianragtop did refinish a ton of stuff on his bug, so he may be right. I would do as Keith suggests and try a magnet on the different parts of the latching mechanism. If it all turns out yo be steel, you should be good to go for zinc.
If non-removable parts are aluminum, you'll need a plan B.
The part I am most suspicious of is the latch housing; the part that sticks out of the door when the latch is installed, and engages the striker plate. I'll try a magnet on mine when I head out through the garage... _________________ Plate of shrimp |
Posted: Tue May 17, 2016 9:08 am Post subject: Re: How do you guys restore door lock mechanisms hardware? |
The magnet stuck soundly to mine. _________________ Plate of shrimp |
Posted: Sun May 29, 2016 7:27 am Post subject: Re: How do you guys restore door lock mechanisms hardware? |
Steel
Alluminium
