MConstable Samba Member
Joined: May 04, 2004 Posts: 1822 Location: Saint Charles IL
Posted: Wed May 11, 2016 2:10 pm Post subject: High Performance Exhaust Systems |
I've been agonizing over stroker engines for my Thing, really unsure on which way I want to go, how big etc.
I had a 2110 in my crew cab years ago with an A-1 1 5/8" set up, heater boxes and all...it was awesome, but I don't know if I want to go that route with the Thing, one, because of cost, two, I don't really like the looks.
So, I'm thinking smaller stroker, smaller valves heads, and go with a 1 1/2" exhaust which opens up using an exhaust from Vintage Speed or the hi-po one from the Thing Shop.
So yeah, that's my story, just looking for advice.
Thanks! |
74 Thing Samba Member
Posted: Wed May 11, 2016 2:12 pm Post subject: Re: High Performance Exhaust Systems |
Kymco VW had a raised header for Things, but I think they may have gone out of business. Al's Headers in Anaheim made them so you may want to give them a call. They had 1 3/8, 1 1/2 and 1 5/8 avail |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Thu May 12, 2016 10:08 am Post subject: Re: High Performance Exhaust Systems |
Don't limit yourself on engine size just because you don't like the exhaust! The Thing, like a bus, we're underpowered from the factory so big engines make them even more fun
I built the exhaust for my 2232, exits out the stock bumper holes, and sounds good. If you are unsure of what direction you want to go as far as size, we can likely point you in the right direction.
As far as cost goes, once you get into the stroker realm, the difference between a 74 and 84 stroke crank is minimal, and bigger is ususally always better. |
sam_w Samba Member
Joined: March 07, 2002 Posts: 1479 Location: Petaluma, CA
Posted: Thu May 12, 2016 10:58 am Post subject: Re: High Performance Exhaust Systems |
In my 2054 stroker I have an A-1 sidewinder exhaust. I am very happy, it is not cheap, but they have a Thing special that keeps all your ground clearance. This is the only performance exhaust I have seen that does that.
This is from a previous posting.
_________________ 63 singlecab
73 thingster
74 Thing |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2769 Location: The World's Motor Capital
Posted: Thu May 12, 2016 1:13 pm Post subject: Re: High Performance Exhaust Systems |
I'm always interested in creative ideas for an exhaust system with outlets that exit through the bumper holes.
Bashr-
I'd be interested in some photos of your home built setup if you have some available to post.
My '74 has a stock system I bought at the VW dealer in 1983. It's been weld/repaired twice, but it's hanging in there.
Over the years, I have used the S&S header system, a strange (NLA) system called the "Outback" which resembled one of those Monza mufflers, but it was made for a Thing with outlets through the bumper holes. It's lying around here somewhere.
I like the muffler behind the engine for easy access to the valve covers.
The new Vintage Speed muffler looks OK; a little expensive.
I have toyed with the idea of a system resembling the original Kubelwagen with the mufflers near the rear torsion bars...
It would be a tough trick with heat exchangers.
Anyway, I'm always curious to see what others have done. |
Posted: Mon May 16, 2016 7:07 am Post subject: Re: High Performance Exhaust Systems |
mondshine wrote: |
Bashr-
Here is the best I have right now. I modeled it after an exhaust system that is NLA.
