Wallythacker Samba Member
Posted: Wed May 11, 2016 11:04 am Post subject: Stupid puma owner here in desperate need of advice |
Here's the deal.
On July 1 Ontario implements a new vehicle certification process.
After this date kit and limited production cars have a big hill to climb to certify as safe.
Pumas may not certify as the Brasilia chassis has been cut and shortened, right? The new inspection act pretty much says that is a fail.
Here's my specific predicament. I bought a gtc in poor shape framewise. Much rust and pan patches with pop rivets. The interior and fibreglass and glass is all fine. Electrical and motor function are a mystery for now but I can fix that stuff in my sleep.
I can buy a near perfect type 1 chassis (69) with the steering head and all rolling parts for about $500.
Does anyone think I can convert it to a Brasilia chassis with cutting and flame welding?
Until July 1 I can submit such a vehicle for certification.
So, is there anywhere I can see blueprint or documents with dimensions for both the type 1 chassis and the Brasilia? Google was of little help. I feel the factory chassis is beyond a safe repair.
I love a challenge but not an impossibility. |
gr8cobbler Samba Member
Joined: May 04, 2006 Posts: 916 Location: Midlife Crisis, Midwest
Posted: Wed May 11, 2016 7:07 pm Post subject: Re: Stupid puma owner here in desperate need of advice |
You may find more help with this question in the kit car buggy forum. _________________ Gary
Being a cheap old fart is just a front for my actual lack of money. |
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 3198 Location: Downingtown, PA
Posted: Thu May 12, 2016 4:28 am Post subject: Re: Stupid puma owner here in desperate need of advice |
I'm 99% sure that Puma's are on standard chassis - not shortened. Simply measure the wheelbase on the car to find out for sure. |
royraison Samba Member
Posted: Thu May 12, 2016 8:12 pm Post subject: Re: Stupid puma owner here in desperate need of advice |
I have a 77 puma
do an internet search for vw puma ,,information is there.
The platform was either Brazil KG or Brazila
front beam is same as US Ghia rear of frame is same or near to a swing axle type three wheelbase is about ten inches shorter than a bug.
pan halfs are not the same as a KG but can be adapted
Good Luck |
Petfisheric Samba Member
Joined: November 27, 2014 Posts: 121 Location: Knoxville, TN
Posted: Fri May 13, 2016 10:18 am Post subject: Re: Stupid puma owner here in desperate need of advice |
Depending on the year of your Puma it was made on either a Karman Ghia pan up until 1974 after that it would be on the Brasilia pan. The head is different on the Brazil based cars then the German cars so you need to get pan replacements for a Brasilia or KG. If the car was imported into Canada it entered the country as a turn key vehicle, so other than repairing the pan you shouldn't have much of a issue. You will find most parts for Type I will be interchangeable but the brake master cylinder is Brazil only also the oil dip stick if it is a later model. Good luck with the refurbish. |
Posted: Fri May 13, 2016 10:33 am Post subject: Re: Stupid puma owner here in desperate need of advice |
You may want to check out this link http://volksrods.com/forum/showthread.php?t=37144
You may event be able to get ahold of the poster and get some help. |
