prattcm Samba Member
Joined: February 21, 2012 Posts: 13 Location: Ohio, United States
Posted: Tue May 10, 2016 5:31 am Post subject: Large battery under driver's seat? |
I just bought a group 27 battery to use for my house battery. I was originally planning on putting it in the cabinet beside the water tank, but I tried putting it under the drivers seat and I think it could work. It sticks up out of the compartment about an inch, but does not interfere with the seat at all if I put the terminals toward the rear. I was thinking about trying to fabricate a new cover that would go over the battery in this location. Has anyone done anything like this? Thoughts? |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Tue May 10, 2016 6:45 am Post subject: Re: Large battery under driver's seat? |
Go for it. Its been done. Just wont be able to swivel front seat. Be sure to protect the terminals |
Vanhalla Samba Member
Posted: Tue May 10, 2016 8:54 am Post subject: Re: Large battery under driver's seat? |
Please post your progress mate, I've got a group 27 battery I could put into my Vanagon. I thought it was going to have to go under the bench. _________________ 1991 VW Vanagon GL
https://www.instagram.com/bjornthebus/
Parts wanted/needed - A high top. CLK wheels. A weekender rear cabinet and head banger. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue May 10, 2016 4:50 pm Post subject: Re: Large battery under driver's seat? |
x3... _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Sun May 22, 2016 12:26 pm Post subject: Re: Large battery under driver's seat? |
Ok, I finally got around to putting it in this past week. I have a recaro drivers seat so I'm not sure how this would work with the stock seat. I previously had a 44 Ah battery in the battery box but recently upgraded to a larger group 27 to see if I could make it work. I like how it turned out.
I started by drilling out the rivets on the metal lid to remove it.
I then cut a slit in the carpet so I could tuck it into the box behind the battery.
I built this using 3/4 inch plywood. I started with a cardboard template to get it how I wanted then glued and screwed it together. I also added a hole for a Blue Sea usb/12v outlet.
I wrapped it in some fabric that kind of matched the interior (any shade of brown) and mounted an iota battery charger.
I added a piece of cedar to the top and used a carriage bolt to mount it to the cabinet.
I'm happy with how it turned out. It does a good job of covering the battery and provided a good place to mount the charger and add some outlets. |
jimf909 Samba Member
Posted: Sun May 22, 2016 2:40 pm Post subject: Re: Large battery under driver's seat? |
That appears to be extremely well done! And it gives some ideas for mounting a charger, solar controller, fuse panels, gauges, etc. Thank you. _________________ - Jim
Abscate wrote: |
tkic Samba Member
Joined: December 13, 2004 Posts: 34 Location: Portland, OR
Posted: Sun May 22, 2016 3:15 pm Post subject: Re: Large battery under driver's seat? |
Wow, classy work! |
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Posted: Sun May 22, 2016 4:23 pm Post subject: Re: Large battery under driver's seat? |
Sweet great job, like how you used the extra storage. Is the battery bolted down? |
Posted: Sun May 22, 2016 11:11 pm Post subject: Re: Large battery under driver's seat? |
Brilliant mate, well done. _________________ 1991 VW Vanagon GL
Posted: Mon May 23, 2016 3:56 am Post subject: Re: Large battery under driver's seat? |
I like it! I'll take one in the same color...???
- Dave
PS: What's the amp-hour rating on your new battery? _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon May 23, 2016 4:14 am Post subject: Re: Large battery under driver's seat? |
That does look great- Only reservations would be when in an accident or rollover will that battery stay put along with its acid, or will you have an 60# missile flying bout spraying acid on everything.-- So button it up with angle iron frame and a decent lid and box and should be a great spot- AND you will always know when it's over charging. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Mon May 23, 2016 6:00 am Post subject: Re: Large battery under driver's seat? |
Thanks everyone! I debated whether or not some sort of strap was necessary. It does sit pretty snugly in the compartment and I have a grippy rubber pad under it so I don' think it will move much. When the seat is slid back into the driving position about a third of the battery is under the seat, so in the event of an accident the battery wouldn't come out of the box.
As for the battery, it does not have an Ah rating on it, it has a reserve capacity of 140. I got it from a local hardware store and they said it was the most popular battery the Amish people use for their solar setups around here (middle of nowhere, Ohio) and it was only $80. It was cheaper and larger than the previous battery I had and with the new charger I should be able to prevent it from getting too low and killing the battery, which is what happened to the last one. |
RichBenn Samba Member
Joined: November 16, 2005 Posts: 703 Location: Lake Tahoe, NV
Posted: Mon May 23, 2016 6:49 am Post subject: Re: Large battery under driver's seat? |
Flooded Lead Acid batteries are supposed to be in a closed off, vented compartment (or engine compartment) due to supposedly explosive hydrogen gas produced during charging and discharging. Not that I've ever heard of that happening, but there it is. _________________ Rich |
Posted: Mon May 23, 2016 10:10 am Post subject: Re: Large battery under driver's seat? |
wow $80--- did you get the Amish discount.-
I found if I plan for stuff or have a spare part-- I never need it.-- but did have a battery explode all over me and a new jacket once- so - as mentioned- Hydrogen may be a factor. But the spot is pretty tempting if you can figure out a vent that keeps the acid and fumes under control. All those battery locations don't rust thru because of rain. _________________ some days I get up and just sit and think. Some days I just sit.
Posted: Thu May 26, 2016 8:25 am Post subject: Re: Large battery under driver's seat? |
After reading this, I tried to cram my Group 27 AGM battery http://amzn.to/1WWHaJK under the driver seat with no success, it's slightly too big.
The battery box has a sloping angle on the door side, if that didn't exist the battery would slip right in. Did you have to do any massaging to the battery box at all? _________________ 1991 VW Vanagon GL
Posted: Mon May 30, 2016 5:42 pm Post subject: Re: Large battery under driver's seat? |
Vanhalla wrote: |
The battery box has a sloping angle on the door side, if that didn't exist the battery would slip right in. Did you have to do any massaging to the battery box at all? |
I didn't have to do anything to the box, it fit right in. I noticed on the battery you linked it is 12.9" long, mine is closer to 12". |
danfromsyr Samba Member
Posted: Mon May 30, 2016 7:03 pm Post subject: Re: Large battery under driver's seat? |
the Syncro box has a sloped box corner, perhaps all 91's do as well. _________________
Abscate wrote: |
Syncronoid Samba Member
Joined: January 21, 2012 Posts: 1111 Location: Stanford, CA and Bend, OR
Posted: Fri Aug 18, 2017 11:19 pm Post subject: Re: Large battery under driver's seat? |
Just put a MK Battery M50-12 SLD M, 50Ah Deep Cycle AGM under the driver's seat. No mods necessary, battery fits perfect. I know I could have gotten more Ah's in various other configurations, but this was plug and play. Ground right in battery compartment, positive cable routed behind cabinets and refrigerator back to the Lifeline GPL 31XT 125Ah AGM in bottom compartment next to fridge.
_________________ '90 Syncro Westy w/GW2.5L |
