dave1 Samba Member
Joined: September 12, 2003 Posts: 477 Location: United Kingdom, London
Posted: Mon May 09, 2016 12:27 am Post subject: 1953 LHD Barndoor Panel |
Hi,
help required
I've been looking at a 53 barndoor panel van. I notice that the outer sill under the side loading doors has small slots along the sill.
They are 3 >4mm approx in height & 70 > 80mm in length along sill.
Is this the correct original sill panel?
Thanks
Dave |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7045 Location: Lawrenceville, Ga
Posted: Mon May 09, 2016 6:42 am Post subject: Re: 1953 LHD Barndoor Panel |
pictures? _________________ regards
Uli
dave1 Samba Member
Posted: Mon May 09, 2016 7:29 am Post subject: Re: 1953 LHD Barndoor Panel |
Hi
I am unable to upload picture at present but if you put this into the Internet "german cars vw 1953 barndoor panel" you will see the dove blue panel from California, then zoom in & you can just make out the slot under the side load doors which go along the sill
Thanks
Dave |
EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
Posted: Mon May 09, 2016 9:48 am Post subject: Re: 1953 LHD Barndoor Panel |
those do look 'custom'. _________________ regards
Uli
dave1 Samba Member
Posted: Mon May 09, 2016 1:16 pm Post subject: Re: 1953 LHD Barndoor Panel |
Hi guys
Thanks for uploading pictures. If you zoom in on the sill under the side doors in the second picture it is more evident. Let me know your thoughts
Thanks
Dave |
Brian_1952 Samba Member
Posted: Mon May 09, 2016 2:41 pm Post subject: Re: 1953 LHD Barndoor Panel |
My guess is that they fix the bottom of the cargo doors and they came up a little short _________________ (20-024785)Ambulance (20-037784)truck (20-035850)panel
(20-035778)kombi
WANTED 52 parts and NOS sheet-metal |
Franz Samba Member
Joined: March 31, 2005 Posts: 345 Location: Grand Junction
Posted: Mon May 09, 2016 3:50 pm Post subject: Re: 1953 LHD Barndoor Panel |
I remember that bus. It came from Portugal. It had some custom metal work from a very old restoration. My guess would be home made rockers. |
My57Oval Samba Member
Posted: Mon May 09, 2016 6:40 pm Post subject: Re: 1953 LHD Barndoor Panel |
It's got a Judson in it? Or has an emblem anyway. |
dave1 Samba Member
Posted: Mon May 09, 2016 7:18 pm Post subject: Re: 1953 LHD Barndoor Panel |
Hi
Yes it has a 36hp engine with judson |
dave1 Samba Member
Posted: Tue May 10, 2016 1:32 pm Post subject: Re: 1953 LHD Barndoor Panel |
Ok guys why the sill with the slots especially as they are so neat with the same width & length? |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2103 Location: Graz, Austria, Europe
Posted: Sun May 15, 2016 10:01 am Post subject: Re: 1953 LHD Barndoor Panel |
it seems as if somebody drilled holes in equal length distance so he was able to bend the rocker panel from flat sheet metal more easily, as he maybe had no access to an industrial sheet metal brake. none of that rocker panel looks original to me. _________________ Hotrods, Fords, Veedubs and Triumph Twins !
Barndoor + Kohlruss Coachbuilt and Oval afficionado
62 Dickholmer, custom color Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
