FlatfourFrenchy Samba Member
Joined: March 13, 2013 Posts: 297 Location: Boonville, MO
Posted: Sun May 08, 2016 12:38 pm Post subject: 8 mm head stud kit for a 71 bus. Is there such a thing? |
Can anyone direct me to an 8mm head stud kit for a 71 bus. It does NOT have the deep stud in #3. The last set that I bought wouldn't work. Even with cutting off as much as I could most of the studs were too long. Did I just get the wrong set? All of the sets that I see for sale have one extra long one minus a mid length stud. HELP me please. _________________ 1971 Tin Top Westy Campmobile 70 |
Posted: Sun May 08, 2016 12:47 pm Post subject: Re: 8 mm head stud kit for a 71 bus. Is there such a thing? |
all the new kits are going to have the 9 of the long studs for deep studded cases. Best thing to do is buy that kit, and buy a single medium length stud for that #3 outer one and use that.
The deep studding prevents case cracking behind #3. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Sun May 08, 2016 1:20 pm Post subject: Re: 8 mm head stud kit for a 71 bus. Is there such a thing? |
Ok thanks. I haven't seen singles for sale. Maybe I got an incorrect kit. I would have to use 5 or six thick washers on each stud to be able to tighten down nuts before running out of threads. Way too long on all of them. _________________ 1971 Tin Top Westy Campmobile 70 |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Sun May 08, 2016 3:03 pm Post subject: Re: 8 mm head stud kit for a 71 bus. Is there such a thing? |
You may have a '71 bus, but you evidently do not have a stock '71 bus case. You need to get the stud kit that suits your case. Also, dual-port head studs are not the same
as single port. _________________ '67 bug: seized by the authorities
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
Posted: Sun May 08, 2016 3:13 pm Post subject: Re: 8 mm head stud kit for a 71 bus. Is there such a thing? |
All 8mm stud cases have #3 deep stud
The kit is right, your engine is wrong |
Posted: Sun May 08, 2016 3:15 pm Post subject: Re: 8 mm head stud kit for a 71 bus. Is there such a thing? |
It is a bus case and letters indicate that it is a 1971. It is an AE case. _________________ 1971 Tin Top Westy Campmobile 70 |
modok Samba Member
Posted: Sun May 08, 2016 3:26 pm Post subject: Re: 8 mm head stud kit for a 71 bus. Is there such a thing? |
Right, so it was 10mm studs and it DID have the deep #3,
someone has converted it to 8mm studs and eliminated the deep stud. |
Posted: Sun May 08, 2016 3:28 pm Post subject: Re: 8 mm head stud kit for a 71 bus. Is there such a thing? |
Ok, thanks. _________________ 1971 Tin Top Westy Campmobile 70 |
Posted: Sun May 08, 2016 4:37 pm Post subject: Re: 8 mm head stud kit for a 71 bus. Is there such a thing? |
Ok, maybe someone changed the inserts to 8mm but are there different length of studs for let's say a stroker motor, that I recieved. I wouldn't know why 8mm studs would have to be a half inch longer or more than 10mm studs. I cut them down and they still almost touched the rocker arm shaft. Maybe the person I got them from had no idea what he had. _________________ 1971 Tin Top Westy Campmobile 70 |
Posted: Sun May 08, 2016 4:50 pm Post subject: Re: 8 mm head stud kit for a 71 bus. Is there such a thing? |
there are head stud kits which are 1/2-1" longer than stock, they are rarely needed. But if your stuff wasn't marked, it's possible that's what you go and why you had such an issue. _________________ It's just advice, do whatever you want with it!
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Mon May 09, 2016 6:39 am Post subject: Re: 8 mm head stud kit for a 71 bus. Is there such a thing? |
[email protected] wrote: |
there are head stud kits which are 1/2-1" longer than stock, they are rarely needed. But if your stuff wasn't marked, it's possible that's what you go and why you had such an issue. |
Oh yeah, I have gotten those "extra long" kits and they are marked as stock length. That would require you to cut every stud.
People may laugh but EMPI sells the BEST studs kits out there. The studs are always straight and the thread length is correct. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Mon May 09, 2016 7:05 am Post subject: Re: 8 mm head stud kit for a 71 bus. Is there such a thing? |
People may laugh but EMPI sells the BEST studs kits out there. The studs are always straight and the thread length is correct. |
Does anybody know if they are the same Chinese stuff EMPI has been selling for many years or are they the former Bugpack products that were correctly made with the rolled threads? _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Mon May 09, 2016 8:50 am Post subject: Re: 8 mm head stud kit for a 71 bus. Is there such a thing? |
vwracerdave wrote: |
Does anybody know if they are the same Chinese stuff EMPI has been selling for many years or are they the former Bugpack products that were correctly made with the rolled threads? |
These are EMPI only stud kits. I have been buying them for 10+ years. I have bought chromoly head stud kits from at least 5 other companies and they are crap.
Again, I am not professing that every EMPI part is the best as there are still some that I flat out refuse to use BUT the stud kits are top quality. _________________ Please "LIKE" us on facebook to see what we are working on.
www.mofoco.com
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Mon May 09, 2016 9:49 am Post subject: Re: 8 mm head stud kit for a 71 bus. Is there such a thing? |
I was fortunate enough to grab a couple ARP 8mm kits during the short time they were available. Perhaps someone could persuade ARP to make more .. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Posted: Wed May 25, 2016 3:39 pm Post subject: 8 mm head stud kit for a 71 bus. Is there such a thing? SOLVED |
Today my VW parts guy figured out my troubles and the incorrect length. Those studs were for a Mexican Head that requires head studs to be longer due to head castings. I got the ones that I needed to finish the transition that someone started by changing it to 8mm inserts. Thanks for your time and answers. It lead us in the right direction to solve this. _________________ 1971 Tin Top Westy Campmobile 70 |
