gblair Samba Member
Posted: Sat May 07, 2016 8:46 am Post subject: Rivets for 74 rear air scoops |
I know there has to be a different name than air scoops but I think you get the picture. I need to know what rivets should be in these. I think there are 2 different sizes. Where can I get them? I am heading to see the progress now on the car and they ask about the rivets. Hope I see some progress.
Thanks |
tallman206 Samba Member
Joined: January 06, 2006 Posts: 316 Location: St.Petersburg Florida USA
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Sat May 07, 2016 12:45 pm Post subject: Re: Rivets for 74 rear air scoops |
The front 2 are 1/8 and the others are 3/16 |
gblair Samba Member
Posted: Sun May 08, 2016 4:21 am Post subject: Re: Rivets for 74 rear air scoops |
Thanks
Are the heads of the rivets normally painted or left unpainted?
Ron in the link provided someone mentioned you screwing them on instead of riveting them on. Can you give details on that? If they are screwed on isn't it easy to remove and clean in there? Years ago we had a tool that would crimp inserts in sheet metal. I don't remember what the name of that tool was but it worked great back in the day. Funny how much you forget in 20 years. Use it or loses it. |
gblair Samba Member
Posted: Sun May 08, 2016 4:30 am Post subject: Re: Rivets for 74 rear air scoops |
I guess Nutsert or rivet nut is what they are called. What to you think about those? |
Posted: Sun May 08, 2016 5:47 am Post subject: Re: Rivets for 74 rear air scoops |
We have used nutserts on all except the original cars we have restored. Factory did not paint the heads on the rivets. Hope to see you in Tipp City in July. |
gblair Samba Member
Posted: Sun May 08, 2016 6:10 am Post subject: Re: Rivets for 74 rear air scoops |
What size to you use and do you use the same size in all of the holes or 2 different sizes? Thanks for the info and if all goes well we will be in Tipp again this year |
Posted: Sun May 08, 2016 7:21 am Post subject: Re: Rivets for 74 rear air scoops |
I have used a few sizes. Most have been 5mm with stainless allen head bolts. Button head looks great also. My tan car has 10-32 bolts . McMaster-Carr is were I buy from. We don't know why VW used smaller front size. I don't when installing bolts. |
74 Thing Samba Member
Posted: Sat May 14, 2016 9:22 am Post subject: Re: Rivets for 74 rear air scoops |
Ron Domeck wrote: |
What is the clamping dimension of the rivets (material thickness), do you use alum/alum or alum/steel (flange/mandrel), and finally do you use open end or closed end rivets when replacing the originals?
Thanks! |
Posted: Sun May 15, 2016 6:20 pm Post subject: Re: Rivets for 74 rear air scoops |
Get them for 1/4 grip range and I use alum/steel. With the steel mandrel you have more power to pull before the pop. Open end. Will we see you in Tipp City? |
