Julio_Arcos123 Samba Member
Joined: August 28, 2011 Posts: 52 Location: Los Angeles, California
Posted: Fri May 06, 2016 3:46 pm Post subject: What order to paint a full car? |
So im going to be painting my car on monday, inside and out, so i was wondering what order i should paint it? The hood, decklid, and fenders are off. Still trying to find a place to hang the doors. So which should get painted first? I was thinking the inside with jambs first then roof then sides, then repeat? Any suggestions? Thanks |
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Sat May 07, 2016 2:50 am Post subject: Re: What order to paint a full car? |
So much crap gets blown around painting the inside that it's a really bad idea to try and paint the outside at the same time. |
air-h2o-air Samba Member
Posted: Sat May 07, 2016 9:55 pm Post subject: Re: What order to paint a full car? |
it will also depend on the color and if metallic...many times you can not panel paint metallics, unless you are a pro....the metallic will lay different and can make the color look entirely different |
Posted: Sun May 08, 2016 6:59 am Post subject: Re: What order to paint a full car? |
Its just a solid color (L380) so there wouldnt be any mettalic or shade difference |
benchracer1 Samba Member
Joined: September 24, 2006 Posts: 583 Location: ramona
Posted: Sun May 08, 2016 7:08 am Post subject: Re: What order to paint a full car? |
definitely spray the inside and outside at different times. Also spend a few extra bucks and buy decent masking paper. Newspaper contains alot of lint....Steve |
Posted: Mon May 09, 2016 6:32 pm Post subject: Re: What order to paint a full car? |
So i found i place to hang the doors. I vacuumed the inside of the door then placed some masking paper inside to prevent dirt lifting up. I painted the doors, decklid and hood off. I started started with the pieces first coated them all then eent to the body. I did the roof first, then rear quarter panels, rear apron, doorjambs, front quarters then front apron. Then i went inside and sprayed the dash and under it. I ran a tack cloth over it after it flsshed to get any dirt debris or dry paint, there wasnt much but just for safety. It came out pretty good. Only a run on the bottom end of the hood and near the door but nothing bad.
kman Samba Member
Posted: Wed May 11, 2016 4:22 am Post subject: Re: What order to paint a full car? |
Ah. I thought you meant engine bay, interior, stuff like that. Plus you have a proper booth which helps tons. Looks good. |
Posted: Wed May 11, 2016 6:46 pm Post subject: Re: What order to paint a full car? |
I was going to spray engine bay and frunk but didnt have time to sand those areas |
