Maineshops Samba Member
Joined: April 23, 2016 Posts: 29 Location: Ludlow maine
Posted: Fri May 06, 2016 2:46 pm Post subject: Breaks |
Got the thing running pretty good waiting for a dwell tach and timing light to finish tuning .
Got hard break peddle but not stopping like I think it should.?
I realize I'm used to power breaks but I don't know what to expect out of this old girl. Dan |
Posted: Fri May 06, 2016 2:59 pm Post subject: Re: Breaks |
They work best when properly adjusted. This will still require a lot more force on the pedal than you would need with any power brake system out there. Having the right linings will help reduce pedal effort. |
tallman206 Samba Member
Joined: January 06, 2006 Posts: 316 Location: St.Petersburg Florida USA
Posted: Fri May 06, 2016 3:44 pm Post subject: Re: Breaks |
If there is any brake fluid, grease or oil on the linings from leaking seals, braking efficiency will be reduced. _________________ Jerry Henning
Southern Classic Works
St.Petersburg, Florida
1973 VW Type 181 with 616/33-6 powerplant
1962 356B-T6 Cabriolet Rustbucket |
Posted: Fri May 06, 2016 3:46 pm Post subject: Re: Breaks |
And they are more commonly referred to as BRAKES, not BREAKS. _________________ Jerry Henning
hobie16 Samba Member
Posted: Fri May 06, 2016 4:52 pm Post subject: Re: Breaks |
tallman206 wrote: |
And they are more commonly referred to as BRAKES, not BREAKS. |
If the BRAKES don't work there will be BREAKS. _________________ Don't be fooled by appearances. In Hawaii, some of the most powerful people look like bums and stuntmen.
--- Matt King
If anything’s going to happen, it’s going to happen out there.
---Captain Ron |
Posted: Sat May 07, 2016 5:28 am Post subject: Re: Breaks |
Original breaks and I pulled the right front and there is no wear. There are no leaks only 17,000 miles on this old girl but rough ones . It was use to hunt jack rabbits in Wy.
If you are familiar with iPad it does some creative spelling, and if you really want to get a kick put it on CC. What a hoot Dan |
