Horn not working. Relay?
kirk knighton
kirk knighton is offline
PostPosted: Thu Apr 28, 2016 3:54 pm    Post subject: Horn not working. Relay? Reply with quote
I hear a "click" sound from above the fuse panel when pushing the horn. No horn, just a "click". Is my relay bad? Are they hard to find?
raygreenwood
raygreenwood is offline
PostPosted: Thu Apr 28, 2016 5:15 pm    Post subject: Re: Horn not working. Relay? Reply with quote
If te relay is clicking...it means the switch in the ateering wheel works....its getting power. Its possible it has some corrosion and its not transfering the power to the horn .....but most commonly its bad grounding at the actual horns or a disconjected wire at the relay.
Let me look at the diagram real quick. Ray
