luvium Samba Member
Posted: Mon May 02, 2016 5:54 pm Post subject: Re: 1964 Family Beetle Build |
grandpa pete wrote: |
I have a suggestion ;
Stop taking things apart and start reading the project and build threads for your year car ;
You will save money and time by learning from others mistakes and not repeating them .
It really is worth your time . |
I read them everyday, learning a lot, my goal in the next two weeks is to get the body off, tough with a 3 yr old "helping".
Btw 50/50 mix of atf and acitone works great. |
luvium Samba Member
Posted: Sun May 08, 2016 5:21 pm Post subject: Re: 1964 Family Beetle Build |
Moving forward, we got the body separated from the pan today, put blocks between until I build a rack to hold the body. It was rough getting them separated even with all the bolts off, like opening a 55 yr old coffin.
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2006 Location: Texas
Posted: Sun May 08, 2016 7:24 pm Post subject: Re: 1964 Family Beetle Build |
Progress! Looking good! _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
Joseph DR Samba Member
Posted: Sun May 08, 2016 7:43 pm Post subject: Re: 1964 Family Beetle Build |
Lotsa work ahead but FUN build!
Next, I would get the seats out, glass, door cards...
Yeah make sure you put screws, nuts, bolts in ziploc bags and label 'em with a Sharpie.
Keeping your parts organized now will save you TONS of time later! _________________ 1964 Beetle |
luvium Samba Member
Posted: Sun May 08, 2016 8:05 pm Post subject: Re: 1964 Family Beetle Build |
Joseph DR wrote: |
Keeping your parts organized now will save you TONS of time later! |
It has been fun so far.
Seats are out, interior is stripped, parts are in ziplocks labeled. I have Rubbermaid bins labeled with its contents. |
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Mon May 09, 2016 9:48 am Post subject: Re: 1964 Family Beetle Build |
luvium wrote: |
Moving forward, we got the body separated from the pan today, put blocks between until I build a rack to hold the body. It was rough getting them separated even with all the bolts off, like opening a 55 yr old coffin. |
Two very simple saw horses worked well for me. I bought the metal brackets from Home Depot and used some left over 2x4s I had laying around.
The body breaking free from the pan is a pretty satisfy sound! _________________ 1976 Westy
1966 Beetle |
luvium Samba Member
Posted: Tue May 10, 2016 7:48 pm Post subject: Re: 1964 Family Beetle Build |
Got the chassis out today with some help from the neighbors and wife.
Now my front yard looks country, putting the pan on dollies in the garage and a car cover on the body. Next step is pans off this weekend.
The po, my wife's aunt said the original owner that bought it new and sold it in 66 named it Betsy, so I guess the car now has a name.
DadsOld74 Samba Member
Joined: October 01, 2013 Posts: 138 Location: Cody, Wyoming USA
Posted: Tue May 10, 2016 11:11 pm Post subject: Re: 1964 Family Beetle Build |
What a great project! I'm looking forward to watching it come together. Have fun! _________________ --Brian ('74 standard bug)
"If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche |
luvium Samba Member
Posted: Fri May 13, 2016 9:31 pm Post subject: Re: 1964 Family Beetle Build |
Pulled the shocks off, brake lines, master cylinder, petal Assy, cleaned a spot in the garage for the pan. |
luvium Samba Member
Posted: Sat May 14, 2016 4:15 pm Post subject: Re: 1964 Family Beetle Build |
Today we got the chassis is the garage and removed one pan, cleaned up most of the edge and off to the Billy Joel concert.
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
luvium Samba Member
Posted: Tue May 17, 2016 8:20 pm Post subject: Re: 1964 Family Beetle Build |
After getting it in the garage I can see she has been in a collision on the front drivers side. The left side of the beam along with the frame head is pushed back 1/2 inch, the left side of the frame head bottom plate is curved. Just the left side is bent, the center where it goes back to the nap hat is straight, well it looks straight.
I know I need a new beam but can I heat up the frame head and try to pull it back out?
Do I need to replace it?
Cowbeze15 Samba Member
Joined: October 17, 2012 Posts: 3 Location: San Diego, CA
Posted: Tue May 17, 2016 9:34 pm Post subject: Re: 1964 Family Beetle Build |
Nice build, good luck. I just started my build on a 66 here in San Diego. Where in SD are you? Im in North San Diego and could bounce somethings off you as i am new to this and seem to be embarking on the same journey. |
luvium Samba Member
Posted: Tue May 17, 2016 9:38 pm Post subject: Re: 1964 Family Beetle Build |
Cowbeze15 wrote: |
Thanks, it's my first build so it's been interesting and fun. I'm in mt helix.
Pm me your contact. _________________ My 64 Family Beetle Build
http://www.thesamba.com/vw/forum/viewtopic.php?t=653448&highlight= |
luvium Samba Member
Posted: Thu May 19, 2016 8:38 pm Post subject: Re: 1964 Family Beetle Build |
Got the left side grinded and cleaned up, I found some heavy surface rust on the tunnel where it meets the pan, grinded it off, hope to get one pan welded in next week.
vwnut1 Samba Member
Posted: Sat May 21, 2016 6:19 am Post subject: Re: 1964 Family Beetle Build |
A diamond in the rough, I love it. I would re-spray in the original VW blue color when it comes time for body work and paint.
After doing a body on pan restore on a '64 I can share that the project is going to take longer than expected. Also, start a build diary and get a folder to help organize receipts for every new/used part that you purchase. You will be surprised at how fast it adds up! _________________ 1957 VW Oval Resto Mod |
carcrazed Samba Member
Posted: Sat May 21, 2016 7:06 am Post subject: Re: 1964 Family Beetle Build |
luvium wrote: |
Nice work and I bet it is a fun build so far. Watch those bare feet with metal shards!! Can't walk in bare feet in my part of the country due to frost bite or have mud between your toes from the mud because of all this stupid rain. Keep up the good work! _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
luvium Samba Member
Posted: Sat May 21, 2016 8:15 pm Post subject: Re: 1964 Family Beetle Build |
carcrazed wrote: |
luvium wrote: |
Nice work and I bet it is a fun build so far. Watch those bare feet with metal shards!! Can't walk in bare feet in my part of the country due to frost bite or have mud between your toes from the mud because of all this stupid rain. Keep up the good work! |
Thanks, I keep a clean garage floor, got a 3.5 yr old running around, it was 80 that day. We could use some of that rain here, looking like we will be lucky to get more rain before November. _________________ My 64 Family Beetle Build
luvium Samba Member
Posted: Sat May 28, 2016 9:58 pm Post subject: Re: 1964 Family Beetle Build |
Today I removed spring packs and beam.
I found a free straight used beam I'm going to clean up and install, then start putting things back together. I plan to get the new pans welded in next week.
txoval Samba Member
Joined: January 23, 2004 Posts: 3553 Location: The Woodlands, TX
Posted: Sun May 29, 2016 12:08 pm Post subject: Re: 1964 Family Beetle Build |
You may have already, but you need to verify if your frame head is bent or not.
That a major repair if so...do not weld in your pans until you know. The frame head would be near impossible to bend back in place, it must be cut off and replaced |
