Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sun May 22, 2016 10:08 am Post subject: Re: My new 68 Fastback "Desert Rat" |
Better test your brakes Soon to see if you need any new rubber flex hoses to the wheels, if you intend to go to the Northwest VW Bug Run,show,swap,drags etc @ www.woodburndragstrip.com in 2 weeks! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
stonecoldcars Samba Member
Joined: February 21, 2013 Posts: 265 Location: Oregon
Posted: Sun May 22, 2016 8:09 pm Post subject: Re: My new 68 Fastback "Desert Rat" |
Mike Fisher wrote: |
Better test your brakes Soon to see if you need any new rubber flex hoses to the wheels, if you intend to go to the Northwest VW Bug Run,show,swap,drags etc @ www.woodburndragstrip.com in 2 weeks! |
I'm not even gonna chance it Mike, I've already purchased them and will replace them. _________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395 |
Posted: Tue May 24, 2016 8:05 am Post subject: Re: My new 68 Fastback "Desert Rat" |
Last nights achievements were. Injectors re-installed, all new fuel hoses, Installed a mechanical fuel pressure gauge so I can monitor pressure at any time, re-installed MPS with new mounts, installed fuel pump with new mounts, new master cyl installed, and than ran out of fuel hose to plumb the rest. Also thanks to Jim Adney for the heads up on the fuel neck overflow hose. it was destroyed rotten. so I have one of those coming for replacement too. So progress is progress.. _________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395 |
Posted: Wed May 25, 2016 1:10 pm Post subject: Re: My new 68 Fastback "Desert Rat" |
Getting pretty excited, I'm down to hooking up the two hoses to the bottom of the fuel tank, pour some gas in and than I get to see if this project will run.. While I had the tank still out I thought I would see if the fuel pump would run with key cycle since accessibility at this point is much better than with the tank installed. Well by no surprise...Turned the key and Nothing.. Checked the plug at the pump, Nothing.. So started with main relay.. Found no wire at terminal 30, so that = no +battery voltage supplied to relay. Made up a wire to battery and bingo, relay kicked over that allowed current to be sent to the fuel pump relay. Moved onto fuel pump relay and found that I had battery voltage, had ignition voltage, but had poor ground from computer. Cleaned the grounds... BAM relay works and fuel pump kicks on.. SWEET... Than I ran out of play time and quit for the night.. _________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395 |
inzel Samba Member
Joined: April 11, 2014 Posts: 196 Location: Spokane, WA
Posted: Thu May 26, 2016 6:43 am Post subject: Re: My new 68 Fastback "Desert Rat" |
Vid of it firing up? _________________ --inzel--
66 Bug
69 Fasty
Old school Sandrail |
Posted: Thu May 26, 2016 8:05 am Post subject: Re: My new 68 Fastback "Desert Rat" |
inzel wrote: |
Vid of it firing up? |
YES! That will be the plan my friend. This weekend hopefully will be a successful weekend on the desert rat. Goal is to get it running, and hopefully well. Than hit the brakes. I've already installed a new master cyl, new front soft hoses. Checked front caliper operation using compressed air. They seem to work. Still need to remove rear drums, check shoes and hardware, replace rear soft hoses, inspect and/or replace wheel cyl's.. So we'll see how far I get.. I will post progress and pics.. Down to a week and a couple of days for Woodburn show.. If that falls apart I'll shoot for the Fathers day show here in Eugene. _________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395 |
t-royR Samba Member
Joined: April 19, 2012 Posts: 464 Location: Minnesota
Posted: Thu May 26, 2016 12:25 pm Post subject: Re: My new 68 Fastback "Desert Rat" |
when you checked the injectors with the 9 volt batter, were they still in the car, or had you removed them? _________________ T-roy
75 Super
71 Super
71 Ghia coupe auto-stick
71 Ghia conv
69 Fasty
74 Ghia conv |
Posted: Thu May 26, 2016 12:26 pm Post subject: Re: My new 68 Fastback "Desert Rat" |
t-royR wrote: |
when you checked the injectors with the 9 volt batter, were they still in the car, or had you removed them? |
Removed, check out my you tube video. _________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395 |
t-royR Samba Member
Posted: Thu May 26, 2016 12:28 pm Post subject: Re: My new 68 Fastback "Desert Rat" |
did you pull the injectors while the engine was in the car? Wondering how difficult that is. I should have done so when I had the engine out. _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
Posted: Thu May 26, 2016 12:43 pm Post subject: Re: My new 68 Fastback "Desert Rat" |
t-royR wrote: |
did you pull the injectors while the engine was in the car? Wondering how difficult that is. I should have done so when I had the engine out. |
yes I did, its not hard. 1/4" drive rachet , small extension, 10mm socket. _________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395 |
Posted: Sat May 28, 2016 9:35 am Post subject: Re: My new 68 Fastback "Desert Rat" |
Well today after work is the big day to see if we have success in this desert rat starting.. I received in the mail yesterday from Jim Adney my improved fuel tank overflow/vent hose to install. Than just need to hook up the two hoses to the bottom of the tank add some gas and give it a go.. I'll let ya all know and a video.. _________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395 |
Posted: Sat May 28, 2016 12:50 pm Post subject: Re: My new 68 Fastback "Desert Rat" |
Sitting here at work thinking about any possible problems I may run into this afternoon. I've replaced every rubber hose except the 4 connecting ones at the intake plenum. they look to be in good shape, however they can be turned by hand. I was going to just put clamps on them, but thought maybe they were a flex joint as such? how concerned should I be on these as a substantial vacuum leak source? BTW this pic is not current.
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Sat May 28, 2016 5:51 pm Post subject: Re: My new 68 Fastback "Desert Rat" |
Well that was short lived. Og pump leaks like crazy. Off to the parts house for a airtex I go _________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395 |
Posted: Sat May 28, 2016 9:56 pm Post subject: Re: My new 68 Fastback "Desert Rat" |
Found a new delphi pump. A cross referenced one from the airtex E2000. Got it installed kind of a pain to figure out how to and where to mount it. But it's done. Videos are uploading now for the attempted starting, stay tuned.. _________________ My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395 |
