Newly Aquired - 1971 Military Thing
Page: Previous  1, 2
HUGO bOSS
HUGO bOSS is offline
PostPosted: Sun May 01, 2016 10:03 am    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
Yours still have the heating system?
http://www.thesamba.com/vw/forum/viewtopic.php?t=538182
jmf337
jmf337 is offline
PostPosted: Mon May 02, 2016 7:51 am    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
It does, its missing a few pieces, but the majority is there. I will look for the stickers tonight, I just got back in town and haven't had much time to do anything.
HUGO bOSS
PostPosted: Wed May 04, 2016 3:29 pm    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
Ok. Wink
jmf337
jmf337 is offline
PostPosted: Wed May 04, 2016 3:49 pm    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
No sticker under my hood. Sad
I looked for an outline thinking it may have been painted over, but no luck.
HUGO bOSS
PostPosted: Thu May 05, 2016 3:33 pm    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
Confused
I have allready seen one on the net with the number painted...
I'm trying to restore mine to original condition... with all the military parts and configuration, but sometimes is dificult to find them... and ones are the stickers...
Should be on the left side a "12V" one (the same as the beetles...
http://www.justkampers.com/12-volt-door-pillar-sticker-for-vw-beetle-1967-1998.html
The gear levels on the center dash (again the same as the beetle), the tire pressures (beetle) and pressure of the water thank to the windshiled (beetle)... but the ones like this one, the ones for the cars with antenna, the speed limit... very rare and dificult, even replicas...
droff85
droff85 is offline
PostPosted: Mon May 09, 2016 8:18 pm    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
In the pictures of underneath is that a swing axle trans? If so how level does it sit? I've got a redux box trans and hadn't ever thought about using it in a thing but I'd imagine it would make for a lot more off road capabilities.
jmf337
jmf337 is offline
PostPosted: Tue May 10, 2016 4:31 am    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
Yes it is, and it sits quite level, if anything the front is up a tad. You can slightly see the difference in the pic below. I'm not sure if the front suspension is any different form civilian models.
I don't think it would be too hard to swap transmissions, it seems all you would need is the longer spring plates (and the RGB trans, of course Very Happy ) and possibly your nose cone off the original trans.
Jim Hunter
Jim Hunter is offline
PostPosted: Wed May 11, 2016 2:55 pm    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
Very nice car.
These early German built 181s have reduction gears at the back and you need also beetle spring plates to eliminate them...Check the transmission code , AK is non LSD and if you are lucky AL is with the ZF LSD , both are K 8/31 R&P...If you like to remove the reduction gears from your transmission you also have to flip the diff...
Jim
HUGO bOSS
PostPosted: Wed May 11, 2016 2:59 pm    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
Smile yeap, thatīs right.
But the ones after 1974 dont have reduction gears from factory...
Going to restore?
jmf337
jmf337 is offline
PostPosted: Thu May 12, 2016 5:36 am    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
Jim Hunter wrote:
Very nice car.
Jim
Thank you Jim.
My Transmission code is AK. It was a bit of a let down as Ian thought is was the AL model.
HUGO bOSS wrote:
Going to restore?
I'm not 100% sure. I sent off for the birth certificate, so I'm curious to see how that pans out. I told myself I would never make another car pretty after doing a Bus, but if there is a car that would change my mind, it may be this one.
Jim Hunter
PostPosted: Thu May 12, 2016 8:10 am    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
Hmm seems that you dont have an ZF LSD , BUT the stamp before the transmission code indicates that you have a factory rebuilt unit !
Jim
jmf337
jmf337 is offline
PostPosted: Thu May 12, 2016 8:21 am    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
Jim Hunter wrote:
....the stamp before the transmission code indicates that you have a factory rebuilt unit !
Jim
Thank you for clarifying that! My motor has the same markings and it was throwing me for a loop as I have never come across them before. Come to think of it the marking is on my starter too.
HUGO bOSS
PostPosted: Thu May 12, 2016 1:12 pm    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
Allways learning! Smile
jmf337
jmf337 is offline
PostPosted: Thu Jul 28, 2016 11:57 am    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
Got the water tight ignition in the mail just recently. I have been doing a lot of searches for the wiring schematics for these and have had no luck. Does anyone know how these are wired up? Those 2 xtra components hanging off the distributor are quite foreign to me.
Fiatdude
Fiatdude is offline
PostPosted: Thu Jul 28, 2016 12:32 pm    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
Arkansauced wrote:
jmf337 wrote:
Sadly no, theres a few things I need to hunt down first. I'm also quite busy with a 2 year old. Very Happy
I can understand that, my hobby takes a backseat too:
2.5 yr old
15 month old
Next one due 7/19
I have to negotiate for time in the garage.
I think you NEED to spend more time in the garage LOL
Remember, as you travel the highway of life,
For every mile of road, there is 2 miles of ditch
Pbotsonis
Pbotsonis is offline
PostPosted: Tue Sep 20, 2016 4:33 pm    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
I went and looked at this one last weekend.
I'm sure they came in on the same fleet....
They are pretty cool cars
http://denver.craigslist.org/cto/5759853198.html
Eric Goodman
Eric Goodman is offline
PostPosted: Wed Sep 21, 2016 3:31 pm    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
Did you buy it? Looks good.
1970 Bug (Das Rod)
1973 Thing
www.vwthingregistry.com
www.Facebook.com/vwthingregistry
Pbotsonis
PostPosted: Wed Sep 21, 2016 7:37 pm    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
No. It's in great shape, I just can't take on another project...
perello
perello is offline
PostPosted: Thu Sep 22, 2016 1:02 am    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
First of all, its not water tight, just RF shield.
you can avoid the bottom cilinder (its just a rf filter) and connect the plugs to the dizzy as usual.
Just be aware that normally the coil has no internal resistance, so an external one should be used. Or replace the coil.
Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
jmf337
jmf337 is offline
PostPosted: Thu Sep 22, 2016 12:49 pm    Post subject: Re: Newly Aquired - 1971 Military Thing Reply with quote
Wow! that is a good looking car! Very complete!
Sorry for lack of updates, I have been quite busy with other things. Laughing
I came home to this on Monday, so now its a mad dash to make the car at least look finished.
Page: Previous  1, 2
Page 2 of 2
