madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Tue Apr 26, 2016 9:10 am Post subject: Re: drag racing a bus |
Have your GF watch it,while u make the pass _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Tue Apr 26, 2016 9:33 am Post subject: Re: drag racing a bus |
You need a trailer to pull behind your bus. You could lock your stuff in that. Then somebody would steal the trailer. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2152 Location: Behind the wheel
Posted: Tue Apr 26, 2016 12:55 pm Post subject: Re: drag racing a bus |
https://www.youtube.com/watch?v=s2MOVmKdhX4
I used to pull the 2276 out of my Dragcar and throw it in my Panel for fun.
Best time was a 14.95 in the 1/4.
Taking of the roof rack Gained 5 mph.
It was fun just driving around town and pissing off a few people with it. _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket! |
64 ragtop volks Samba Member
Posted: Sun May 01, 2016 11:31 am Post subject: Re: drag racing a bus |
trailered bus saturday to track. i took all the extra crap off bus, no rack, no swamp cooler, aired down rear tires to 22psi, pulled off the fan belt...went ALL IN on the first pass.... broke an axel leaving line! as we are pushing it back, guy said at least there isnt a huge pool of oil, or any metal chuncks laying down there. ill get it tore down next week and see how bad it broke. ill be using hd axels from now on. lesson learned |
TSPayne Samba Member
Joined: April 23, 2006 Posts: 73 Location: Spokane, WA
Posted: Sun May 01, 2016 12:23 pm Post subject: Re: drag racing a bus |
There was a guy in the Seattle area, years ago, that went by the name of "buggly". He was running 14.5's in a 64 combi! He was crazy fun to watch! I never knew what he was running though. Does anyone remember this guy? |
GTV Samba Member
Posted: Sun May 01, 2016 12:34 pm Post subject: Re: drag racing a bus |
TSPayne wrote: |
I do remember. What happened to him? _________________ EMPI Power Rules! |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Sun May 01, 2016 1:43 pm Post subject: Re: drag racing a bus |
If you want to get serious about improving your times, you'll need to revisit your engine combination. Also, that shroud is one of the shittiest cooling shrouds ever. |
SBD Samba Member
Posted: Sun May 01, 2016 2:44 pm Post subject: Re: drag racing a bus |
bugguy1967 wrote: |
Yeah, but it looks COOL!
henk Samba Member
Posted: Mon May 02, 2016 1:55 am Post subject: Re: drag racing a bus |
There some really fast splitscreen busses at the moment here in europe.
Like windsplit,firebus,the hotwheels bus,...
The firebus even broke the european record last week with a 11,4 on the 1/4 mile.
https://m.youtube.com/watch?v=RbiFfNqnEX0
Henk!!! |
Posted: Mon May 02, 2016 4:16 am Post subject: Re: drag racing a bus |
Quit side steppin the clutch
try to slowly release it on the last Yellow lite _________________ 'Black Ice'Drag Buggy 'Turbo'
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Mon May 02, 2016 9:11 am Post subject: Re: drag racing a bus |
madmike wrote: |
try to slowly release it on the last Yellow lite |
There is a lot more truth to that then most guys understand. I DO NOT side step the clutch, I release it.
OP try 25-26 PSI in the rear tires. Steel belted passanger car tires must have enough air in them to stay round. When they are under inflated the steel belts distort and you will not have maximum traction. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Tue May 03, 2016 10:25 am Post subject: Re: drag racing a bus |
if i had a nickle everytime someone ran their mouth about how "shitty" that center mount shroud is, i would have enough money to buy a second one!!! i have ran that shroud and several roadtrips over 2500 miles without any overheating problems on my roadtrip motor, in this same bus, sure there are better choices but i like it, and tend to do things a little differnt. im having fun, im serious all day long...12 to 14 hours a day, owning a small cnc job shop, so thats why i enjoy having fun when im behind the wheel of my volks. thanks for the tip on psi and radials, ill start out at 28psi after i get the trans sorted out. if i was serious i would not be in this shitbox would i? hahaha
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Tue May 03, 2016 4:43 pm Post subject: Re: drag racing a bus |
64 ragtop volks wrote: |
if i was serious i would not be in this shitbox would i? hahaha |
Good point .. we love seeing it in action _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
SBD Samba Member
Posted: Tue May 03, 2016 5:41 pm Post subject: Re: drag racing a bus |
I see three people in that pic. I'm guessing the driver is you, and one of the other two looks to be taking a pic of the bus. I think that says a lot! I like your shitbox! I'd roll with ya! _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Wed May 04, 2016 2:09 pm Post subject: Re: drag racing a bus |
It seems that the OP did not read my remark about NOT letting too much air out of the rear tires leaving a SNAPPED axle or broken tranny. |
Posted: Wed May 04, 2016 2:20 pm Post subject: Re: drag racing a bus |
HRVW wrote: |
It took me a while to learn how to race on real steel belted street radials. People always give me the stink eye when I tell them to air the damn tires up. You CAN NOT run them under inflated at the track. It will just break you junk. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Thu May 05, 2016 4:15 am Post subject: Re: drag racing a bus |
I had one of them center mounted shrouds on my 917 and had no issues ether _________________ 'Black Ice'Drag Buggy 'Turbo'
Posted: Wed Jun 22, 2016 9:10 am Post subject: Re: drag racing a bus |
hoping to get the shitbox out to test n tune saturday, if i did my math correct i should be able to cruise 50 mph at 3000rpms, i still want to drive it in the street. ill be keeping tires aired up and see how it goes...low 17s / high 16s would be nice for now. im building a 2110 (76×94)draw thru turbo motor just for funzies, but its few months away from being ready |
spencerfvee Samba Member
Posted: Wed Jun 22, 2016 2:25 pm Post subject: Re: drag racing a bus |
the most important thing is your having one hell of a time racing your bus . not every one who drag races has a fast car . .you don't need a fast car to win a race .as long as you turn the same time every time . you would be hard to beat . unless you get a sand bagger . what people on here don't under stand not every one wants a 10 second car or a 14 second car . my friends old 1973 bus runs 25seconds in the 1/4 mile .I don't think his time is all that bad . what do you think a 40hp motor in that bus would run in the 1/4 mile maybe 30 seconds lol. give him time he will get it to run 16s ... licking gas kicking ass . blood sweat and gears lol lol have fun my friend and do it your way .and who gives a dam what others think lol lol spencerfvee
Posted: Wed Jun 22, 2016 5:51 pm Post subject: Re: drag racing a bus |
before breaking the axel, i was hitting low 18s consistantly within a tenth @ 68mph. i just go to the test n tune nights, so its heads up racing, its funny when i catch a v8 sleeping at the lights and get a good jump on them, yeah they pass me by time i shift to 3rd, but the people in the stands are by the starting line in the stands, makes for some very cool pics seeing a ratty 50 year old bus that looks like hell, getting a jump on modern day v8s that the bank still owns, im sure their buddies really bust their balls about it lol |
