Jos.Hall Samba Member
Joined: January 29, 2011 Posts: 336 Location: Sunny So Cal.
Posted: Mon Jul 25, 2016 2:09 am Post subject: Re: 50 (51?) split excavation |
Subscribed because having seen you're past work, I know this won't phase ya. |
Schwing Samba Member
Joined: May 10, 2009 Posts: 2506 Location: Centreville, MD
Posted: Mon Nov 23, 2020 7:01 am Post subject: Re: Aug 50 split |
I have purchased this project from Seth. Seth and I are very good friends. I actually discovered this in the woods a mere 30min from my home 6+ years ago but I wasn't able to land on a price with the seller. The seller died of a heart attack and his son sold this to Seth. For years I would ask/tease/mention/suggest that he sell this to me. Seth is a stand up guy who eventually worked a very fair deal with me.
Let the fun begin.
The plan:
It will be stitched together with as much original panels as I can locate and will show all of its scars. It will not get repainted. I am working on sourcing an oval pan with title. It will stay mostly stock and maintain the spirit of an early split, with some minor touches because I simply can't afford to be a purist. If I can find 16s and they are in the budget, he will stand tall, or it will sit on some 66/67 style wide 5's painted silver. Seth nicknamed the car "Stitch" and I like it.
Here it is being moved from Seth's shop in Philadelphia. It is now in Centreville, MD which is about 20min from where it was discovered.
I purchased all of the donor parts that Seth didn't need for his current 52 project.
The donor parts are almost another Beetle!
This lower section is from another split and was moved here from FL. Its an amazing piece of steel and essentially my jig. It was cut in two so I mounted it to a 62 chassis I had so it can be welded back together. You will see I have full A-pillars too, which will be the first job.
Also a nice dry front clip from another beetle
Its been moving around my shop since I had some other things to wrap up.
Simple enough, put this onto this.
Speedo is in nice condition. We don't know if its a Hoffmann so for now I will run a KMH speedo. _________________ Shadetree Westy
http://www.thesamba.com/vw/forum/viewtopic.php?t=657279&highlight=
Single Cab - BBXXVII Long Distance Winner
Basketcase Samba Member
Posted: Mon Nov 23, 2020 8:11 am Post subject: Re: Aug 50 split |
aswesome when cat guys work with each other. _________________ '72 Karmann Ghia Coupe (the Boss's) |
Rich's 50 Samba Member
Joined: February 18, 2004 Posts: 10781 Location: San Diego, CA
Posted: Tue Nov 24, 2020 10:10 am Post subject: Re: Aug 50 split |
Nice.. looking forward to the updates |
type4split Samba Member
Joined: May 23, 2007 Posts: 681 Location: Hamilton, Indiana
Posted: Fri Nov 27, 2020 5:57 pm Post subject: Re: Aug 50 split |
It’s gonna be fun. Did you get any work done over the last few days ? _________________ '67 deluxe bus w/the little windows
'52 beetle
'55 convertible
'50-something convertible (*need ribbed 'vert quarter panel )
'63 "milo" beetle
Part, parts and more parts |
qwertinatom Samba Member
Joined: November 22, 2020 Posts: 1 Location: Tyne & Wear UK
Posted: Sun Dec 20, 2020 11:14 am Post subject: Re: Aug 50 split |
Really looking forward to seeing this come together! |
Posted: Mon Jan 25, 2021 7:40 pm Post subject: Re: Aug 50 split |
Any updates on progress ? _________________ '67 deluxe bus w/the little windows
'52 beetle
'55 convertible
'63 "milo" beetle
Posted: Wed Apr 14, 2021 9:27 am Post subject: Re: Aug 50 split |
Sorry I am slacking on updates.
I welded together the lower section and also welded in the A pillar on the passenger side. I've also been collecting a lot of the parts that were missing when I purchased the car 7 months ago.
Assuming I can wrap up some house projects, I expect to make excellent progress this summer.
This is a donor a-pillar. I will final weld it in once I can test fit door, which is pending a new internal frame to be welded so the door can open and close.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
sled Samba Member
Posted: Wed Apr 14, 2021 9:54 am Post subject: Re: Aug 50 split |
love it!!
also makes me really thankful I live on the west coast, and in a particularly dry area _________________ drive your split. |
Posted: Sun Aug 01, 2021 6:46 pm Post subject: Re: Aug 50 split |
Any recent work ? _________________ '67 deluxe bus w/the little windows
'52 beetle
'55 convertible
'63 "milo" beetle
David Samba Member
Joined: June 29, 2004 Posts: 2027 Location: Raleigh, NC
Posted: Tue Sep 21, 2021 8:11 am Post subject: Re: Aug 50 split |
Any updates? _________________ Cheers,
Dave
*October '54 Ragtop
Posted: Wed Feb 09, 2022 7:42 am Post subject: Re: Aug 50 split |
how's the project going? _________________ '67 deluxe bus w/the little windows
'52 beetle
'55 convertible
'63 "milo" beetle
Posted: Wed Feb 09, 2022 8:01 am Post subject: Re: Aug 50 split |
I have been slowly gathering parts in between finishing up some side work and some small jobs on my other vws.
A few weeks ago I picked up a titled 55 chassis and front beam which I immediately blasted and primed with help from my friend Seth.
Also picked up a hood handle, pedal assembly, 50 rear apron, and a couple other bits.
I managed to fit the passenger side door and final weld the pillar so its all aligned. I also cut the quarter to match my donor, in preparation for that to be welded.
Slow and steady!
Here you can see the 50 rear apron:
chicagovw Samba Member
Joined: January 06, 2007 Posts: 1424 Location: Chicago IL/CHandler AZ
Posted: Wed May 31, 2023 9:42 am Post subject: Re: Aug 50 split |
Any updates on this? Have you ordered a Birth Certificate to help determine if it is possibly a Hoffman? |
Posted: Wed May 31, 2023 2:00 pm Post subject: Re: Aug 50 split |
That would be great-thank you for the response! |
Posted: Thu Jun 01, 2023 5:17 am Post subject: Re: Aug 50 split |
I have a feeling he may never update this thread so I thought I would bring it to closure. While restoring this split a good friend offered another Aug 50 split (824 units older) to me and it was much further along. While I had the capability of fixing this split, I just couldn't justify the time spent doing it for me personally, while raising a family. So I sold it to my friend who has a restoration business and the SKILLS to get it done.
Here is how it sits now, and it is in fact a Hoffman which is cool because there were only 326 Hoffmans in 1950. It was crazy to think I owned two of them for a few months.
Two Glove Boxes Samba Member
